Cobb question
Old Dec 16, 2010 | 07:09 PM
08blue6r's Avatar
get naked.
Cobb question
Is it normal for the accessport to not hold and idle and stall out for a little while when you load a new map? My car starts and runs fine after I load a new map (including the stock map) except that it stalls when I let off the gas. It usually does this for a good 10 minutes
Old Dec 16, 2010 | 07:46 PM
Flashwing's Avatar
3-wheeler
Depends. If you have excessive fuel trims because of an aftermarket intake or some kind of small vacuum leak then when the PCM is reset it would have trouble idling or stalling.
I had this issue running the K&N Typhoon II intake. It would take 2 or 3 drive cycles before the PCM would adjust enough to keep the car from dying.
Old Dec 16, 2010 | 08:18 PM
08blue6r's Avatar
get naked.
I have the stock intake. Just a midpipe and catback. It idles fine after it gets through it's dying phaze
yankeepicker
Sep 11, 2015 05:42 PM
RenzoRx-8
Sep 9, 2015 02:38 PM
BigBadChris
Sep 7, 2015 01:49 PM
