cschoeps
12-01-2010, 12:31 PM
Hi all,
So snow is finally falling, and it's about time for to tuck the mazda away for the winter. Does anyone have tips for winter storage? :sadwavey:
My current plan is to park it in a garage (with car cover), put in a fuel system maintainer, pump the tires up, and pull the battery out and put it on a battery tender.
Is there anything else I should be worried about? This is my first time storing a car, so I'm trying to make sure I'm not missing anything.
RX8Soldier
12-01-2010, 12:56 PM
Make sure to give it a proper cleaning before parking(not necessary, but recommended). Also, depending on the storage facility, you may wanna cover any holes (intake, exhaust, etc) that pesky rodents could get into.
cschoeps
12-01-2010, 02:57 PM
Thanks! Yea, I figure I'll wash it a couple of days before it goes in, that way I make sure it dries out. Some steel wool in the exhaust pipes should do for keeping out critters.
Youwonder
12-06-2010, 08:40 AM
+1 it's gonna be my first time putting my 8 for storage.. Were can I get the fuel maintainer? Also what does it do?
cschoeps
12-07-2010, 06:53 AM
I picked some up at O'reillys (auto parts store) called sta-bil. From what I've read, it's pretty much the standard fuel stabilizer. It claims to "keep fuel fresh" by "preventing gum and varnish" and "removing water" from condensation.
http://www.goldeagle.com/brands/stabil/products.aspx#stabil
Good luck with the storage! When are you putting it away?
terch1
12-07-2010, 07:16 AM
I keep mine under a car cover. I haven't used any fuel system stabilizers in the 4 years I've owned the car. I also pump up the tires to between 36-38 psi and disconnect the battery. This year I can just use the battery disconnect siince I relocated the battery to the trunk last month. If you have abnormally long winters or if you plan on storing the 8 for a significant amount of time (6+ months) I would rub the tires down with vasoline to avoid dry rot.
Youwonder
12-07-2010, 09:06 AM
I'm actully gonna put my 8 away this Friday since here in NYC it started to get 30f weather.. Thanks for the advice I'm gonna get the fuel stabilizer today Also a car cover plus givE it a good wash....
REsuperD
12-13-2010, 02:23 PM
i have an amateur question regarding battery tenders. i just ordered a ctek battery charger and it comes w/ eyelet terminal connectors, which i'm going to install and just leave on the battery for good. if i do this, do i install the eyelets to both battery terminals? or do i install one to the positive battery post and the other to a negative ground somewhere?
alldaylongcars
03-28-2012, 12:00 PM
My only tip.. Take your car to a storage facility... they usually take care of everything there.
last winter i made the mistake of keeping my car in the garage...
this past winter, used a proper storage company. Just took it out a couple weeks ago and my baby runs great.
if anyone's interested, I used Auto Vault in Toronto.
http://www.autovaultcanada.com/
