Group Buy Center Approved group buys ONLY. To become an approved group buy vendor - go here:
https://www.rx8club.com/payments.php
R1 Concepts Group Buy Brake Rotors Brake Pads and more
Old Nov 18, 2010 | 06:40 PM
r1concepts's Avatar
R1 Concepts Inc. is proud to offer Premier Series rotors!
I am offering the Premium series rotors which are made with stronger iron cast metal (G3500) for overall tension strength. The Premium series rotors which is the top of the line series out of the two that I carry (E-lines & Premiums). The rotors are cast with a 50/50 center split for better heat distribution. Premium utilize a black Electro-coating finish applied on the hubs and inner vane structures providing long lasting corrosion protection. Original stock size, will bolt right up with no modifications needed. Our Eline series rotors are made from a cast iron grade of G3000 which is standard industry use. When ordering a drilled or slotted design, our Eline series rotors also comes with a Silver Zinc rust protection coating to help prevent from rusting. All of our Premier and Eline rotors are direct OE fitment.
What separates R1 from the rest?
Often Imitated, Never Duplicated. Here at R1, we take into account numerous precautions in machining rotors. We drill our rotors in house using state-of-the-art CNC machines and follow strict procedures and standards such as drilling between each vane structure. This will allow the rotor to retain its structural integrity and overall strength with optimum thermal transfers. We utilize smaller diameter drill bits for smaller diameter holes and each hole is counter-sink to add strength. You also have the option to go with slotted only or even a custom design with your own logo. Every R1 rotor that comes with slots will come with our exclusive "Diamond Slot design" (45 degree angle end points), to help release trapped debris. Our diamond slot design is also a good indicator for rotor wear. We also offer optional Cryo Treatment at an additional cost. (Cryogenic treatment is a process that improves the performance and life of the rotor by strengthening the metallurgy. This process will help to give an extra level of protection against warping).
Why are you choosing R1 Concepts Inc?
We’ve been in business since 2002 and have been a supporting vendor on this forum since 2007. With countless sets of rotors/ pads sold (and many other forums) and Top Notch Customer Service to back it up… Buy what's trusted.
*WARRANTY*
Here at R1 Concepts Inc, we stand by our products. We offer a one year warranty on warping and cracking on all R1 brake rotors due to manufacture defects and workmanship for our Premier line. For our Eline series rotors, we offer a one year warranty for warping and one year for cracking.
AVAILABLE STYLES
Slotted Only
Drilled and Slotted
Drilled Only
Dimple and Slotted
04-08 Normal Suspension[/SIZE]
FT/RR PREMIUM ROTORS:
PM FOR PRICING
04-11 Sport Suspension / Touring / Sport
PM FOR PRICING
PADS
FT/RR POSI CERAMIC PADS:
$78
FT/RR STOPTECH PERFORMANCE PADS: $110
FT/RR HAWK HPS PADS: $125
FT/RR HAWK CERAMIC PADS: $138
FT/RR HAWK HPS 5.0 PADS: $145
BRAKELINES
FT/RR STOPTECH STAINLESS STEEL BRAKE LINES: $100
BRAKE FLUID
[/SIZE]
Stoptech STR-600: $15
Typical Dry Boiling Point: 594°F (312°C)
Typical Wet Boiling Point: 404°F (206°C)
Minimum Wet Boiling Point: 383°F (195°C)
Stoptech STR-660: $25
Typical Dry Boiling Point: 622°F (328°C)
CALIPER PAINT[/SIZE]
G2 Caliper Paint:
$33
(all colors of rainbow, black, silver, pink available)
SHIPPING: FREE SHIPPING WHEN YOU PURCHASE ROTORS OR ROTORS+PADS COMBO. OTHERWISE, STANDARD SHIPPING CHARGES (AK, HI AND INTERNATIONAL WILL COST MORE)
Contact Info
[SIZE=3]
IF YOU HAVE ANY QUESTIONS OR WANT TO PLACE AN ORDER.
PM: r1concepts
Email: Kevin@r1concepts.com
Phone: 888-712-6623 ext. 7022
Old Nov 19, 2010 | 04:04 PM
elysium19's Avatar
I bought these a few months ago, very nice guys, and great product for a good price. Nice OEM replacements, OEM size, etc.
Melvin - For what it's worth, I asked you guys to send me a set with the entire rotor face coated with black high-temp paint, in order to prevent a ring of rust on the extreme edges of the rotor face. I know, I'm super **** about it. Anyway, it WORKED PERFECTLY. The only thing I would advise people is that you REALLY NEED TO KNOW WHAT YOU'RE DOING! The "burning off" process takes a while and frankly is scary as **** haha. Makes weird sounds, smoke, smells, etc. Only do one set at a time (rears then fronts, that sort of thing), and set aside some time to do that, have to jack up the car multiple times, and do a thorough and proper bedding sequence AFTER all the paint is gone. But as I said, it came out perfectly, they look amazing.
and I took them to the track the next weekend, and performed basically the same as the OEM brakes....which is to say...very well!
Old Nov 19, 2010 | 04:07 PM
paimon.soror's Avatar
Those are some pretty sick prices. Elysium, do you have any pics of the rotors/the install at all?
Old Nov 19, 2010 | 06:09 PM
r1concepts's Avatar
Thanks for the great feedback, it is a simple process to paint the rotors with high temp paint. The paint can be purchased at any auto parts store and helps prevent the ring rust and rust inside the cross drilled holes and slots for a very long time. I am glad you hear that you are happy with the rotors.
If anyone else needs a set, send me a PM and i can get an order set up for you.
Pictures would be great, cant wait to see them.
Old Nov 20, 2010 | 11:41 AM
elysium19's Avatar
Sure. I actually meant to take some during the install, but forgot. I cant explain how ridiculous a completely black-painted rotor looks both when taking it out of the box and when mounted on the car, before the 30 minutes or so it takes to wear the paint off.
Old Nov 20, 2010 | 11:46 AM
RX8Soldier's Avatar
Time for boost...
Ooo me likey a lot! I have all winter to mod my car. I'll submit to this thread to keep updated
Old Nov 20, 2010 | 11:49 AM
elysium19's Avatar
They look really good. Again, nothing tooo fancy, but great as direct OEM replacements.
And with the paint coating, after wearing the pad sweep area, there isn't a single space for a drop of rust to form at all. After living with an ugly ring of rust on the OEM rotors for years, I am particularly happy about this...
Attached Thumbnails R1 Concepts Group Buy Brake Rotors Brake Pads and more-2010-08-29-19.05.24.jpg   R1 Concepts Group Buy Brake Rotors Brake Pads and more-2010-08-29-19.05.43.jpg   R1 Concepts Group Buy Brake Rotors Brake Pads and more-2010-08-29-19.05.59.jpg
Old Nov 20, 2010 | 03:17 PM
elysium19's Avatar
I know those arent the most flattering shots, and it was from a cell phone camera.
But really, they look worlds better than the OEM ones, trust me.
Old Nov 22, 2010 | 10:41 PM
HockeyRX-8's Avatar
TNC
For premium slotted rotors, are the vanes straight or directional?
Old Nov 22, 2010 | 10:48 PM
RX8Soldier's Avatar
Time for boost...
elysium, you need to repaint your calipers!!!
Old Nov 23, 2010 | 11:01 AM
scremn8's Avatar
the more things change
i bought a complete set from these guys, very nice and friendly
Old Nov 23, 2010 | 03:39 PM
elysium19's Avatar
I know.....I did a pretty rush homemade job of it a few years ago, and it shows. Should do it right and get them powdercoated. I just don't have time now to do it, or have downtime with it, she's my daily driver....
Old Nov 28, 2010 | 02:29 PM
pcs's Avatar
pcs
Hey Melvin - is this a limited time offer? or is this the standing price to forum members? looks good, but my 09 is not in need of new brakes yet...
and is pickup an option if we're local?
thanks,
pcs
Old Dec 9, 2010 | 01:31 PM
r1concepts's Avatar
They are straight vanes.
Originally Posted by pcs
Hey Melvin - is this a limited time offer? or is this the standing price to forum members? looks good, but my 09 is not in need of new brakes yet... and is pickup an option if we're local?
thanks,
pcs
Yes this is for forum members, I do not have an ending date but prices may change in the future. Local pick ups are available, just give me a call or you can pm me whenever you are ready and I can set up an order for you
Old Dec 9, 2010 | 01:42 PM
r1concepts's Avatar
Nice pictures btw Elysium, thanks for posting that up. The high temp paint came out really nice.
Old Dec 31, 2010 | 06:00 PM
rotary bizzawtch's Avatar
how much would it be for a set of front and rear "drilled only" rotors and brakes? also, do you have any that are painted silver instead of black?
Old Jan 4, 2011 | 06:06 PM
r1concepts's Avatar
pm'ed
Old Jan 5, 2011 | 10:31 AM
Guy Hollywood's Avatar
Can you send me prices for slotted only, drilled only, and drill/slotted for both front and rear. I'll also be looking to get some Hawk HPS pads as well if you can include those prices.
Thanks.
Old Jan 5, 2011 | 06:55 PM
r1concepts's Avatar
Thanks.
pm'ed
Old Jan 14, 2011 | 07:00 PM
ttame16's Avatar
can you send me prices for drilled only, slotted only, drilled/slotted and dimple/slotted for front and rear? thanks!
Old Jan 15, 2011 | 03:45 PM
superhypered's Avatar
Yellow RX8
I love drilled AND slotted rotors, could you pm me the price for all 4? and do you have yellow caliper paint as well? thanks
Old Jan 15, 2011 | 11:30 PM
Blacknightz's Avatar
nice...
Old Jan 16, 2011 | 10:11 AM
papadoo's Avatar
Hi sent me price for slot drill for gt 05 they are nice i very interesting
Old Jan 16, 2011 | 12:27 PM
Placed my order with Melvin (r1concepts) the other day for new pads and rotors. I ended up going with the slotted/drilled rotors and Hawk ceramic pads. Even though they don't carry those ceramics in stock, Melvin was able to special order them for me. He was very helpful and prompt in getting back to me. Great prices as well. Hopefully I get everything before next weekend so I can get everything put on. Thanks again.
Old Jan 17, 2011 | 05:22 PM
r1concepts's Avatar
pm'ed
