AT idle ~
Old Aug 26, 2010 | 01:42 PM
ShinkaEvo's Avatar
Triangular Bee Hive
Smile AT idle ~
Got a quick question for AT users.
Which gear do you guys usually put on during idle/stop light?
N or leave it at M?
I used to leave it at M, but recently I started to put it at N for smoother idle.
I'm not a technical person, so I don't know how it'll effect engine or tranny, just want to get an idea of people's driving habit.
Cheers~
Old Aug 26, 2010 | 01:44 PM
blakem2008's Avatar
i usually leave in it m unless its really hot outside then the car tends to heat up a bit more when in m mode...never heard of putting it in
Old Aug 26, 2010 | 04:08 PM
09Factor's Avatar
Original Turbo 'd Auto !!
N or leave it at M?
M usually.
Cheers~
If you are having bad vibration issues, it may be that the motor mounts need replacing. The Right Side motor mount usually fails first. It's failure is caused by close proxemity to the hot exhaust header.
it's not going to effect the motor or tranny either which way. In N or D/M at a stop.
Old Aug 26, 2010 | 06:36 PM
ShinkaEvo's Avatar
Triangular Bee Hive
Already replaced my motor mount once under the warranty.
Next time it'll be out of my own pocket....
Heard people using idemitsu premix to smooth out the rough idle, planning to do that next time.
Old Aug 26, 2010 | 08:42 PM
09Factor's Avatar
If you do that, read up on the Sea-foam thread first.
Old Aug 26, 2010 | 10:38 PM
EdwardLenczowski's Avatar
Put a grounding kit on the car it will smooth out your idle!!
Old Aug 26, 2010 | 11:24 PM
ronx8's Avatar
zoom zoom!
after putting in the BHR ignition kit my idle was much smoother.
threw in a new battery too and it was flat.
Old Aug 27, 2010 | 11:25 AM
ShinkaEvo's Avatar
Triangular Bee Hive
Got a ground kit already, but there is just one spot I can't get to (big/fat hand), the plate that coils mounted on.....I'm noob....
And yes, definitely BHR ignition system, next thing on my list.
Old Aug 27, 2010 | 12:49 PM
Btw bhr ignition is rele good!
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
