Free engine replacement
Old Aug 11, 2010 | 09:34 AM
Neil C's Avatar
I have seen this mentioned quite a few times but do Mazda actually do this for a car that is out of its warranty? If they do, what criteria do they apply?
I am new to the forum so I apologise if this topic has already been done to death.
Neil
Old Aug 11, 2010 | 09:37 AM
Huey52's Avatar
Registered Zoom Zoomer
No.
The Mazda North American engine core warranty is [within-] 8 years/ 100k miles.
Old Aug 11, 2010 | 09:38 AM
RIWWP's Avatar
If you are still within Powertrain warranty, the engine replacement is free assuming it fails a compression test or a vacuum test, or there is some other obvious sign of failure that is warranty covered
If you are outside of Powertrain warranty but within the 8yr 100k engine core warranty, the engine replacement will cost you $500-$600, as you will have to pay for the fluids, gaskets, bolts,, belts, etc.. that have to be replaced along with the engine, but are not part of the engine core itself, and thus not covered by the extended 8yr 100k warranty
If you are outside of the 8yr 100k warranty, the engine replacement will cost you $5,000 to $7,000, depending on the dealer. A cheaper option is a rebuild from one of the forum vendors here, or even buying a used or rebuilt engine. Usually one of these options can be accomplished for $2,500 to $3,500 total.
Old Aug 12, 2010 | 11:30 AM
Mr. Pockets's Avatar
The only currently active warranty on my car is the extended 8yr/100k mile engine warranty. I didn't have to pay a thing for my engine replacement in March. They did make me pay for the compression test that I requested they do, and which led to the conclusion that the engine needed to be replaced.
Old Aug 12, 2010 | 11:34 AM
RIWWP's Avatar
Either lucky or a good dealership. Most can't expect that though. Although the compression test that came back with failing numbers should always be free. Only pay for it if you pass.
I guess they decided to bill differently.
Old Aug 12, 2010 | 11:40 AM
it depends on dealerships.
good ones will not just rip everything apart, so you will not have to pay anything
bad ones just rips whatever they see, and bill you to death.
Old Aug 12, 2010 | 11:42 AM
RIWWP's Avatar
Other good ones might just forget to replace something that they should and you end up with the front of your RX-8 in flames.
Not everything should be re-used, even if it technically can be.
Old Aug 12, 2010 | 12:09 PM
VashGS's Avatar
Zoom Zoom Addict
No such thing as free btw. There is pain involved. This is not some kind of give away. There are ramifications and what not involved.
Old Aug 12, 2010 | 02:41 PM
xShinka666x's Avatar
i have another question about this topic, after your engine is replaced by the 100k warranty does the replacement engine have any kind of warranty on it? or are you just **** outta luck if it fails
Old Aug 12, 2010 | 02:44 PM
VashGS's Avatar
Zoom Zoom Addict
It still stays till either the vehicle hits 100,000, 8 years. Some people are on 3rd engine.
Old Aug 12, 2010 | 02:58 PM
alnielsen's Avatar
I'm on my 4th engine. I seem to remember one person that had 5. In the last 2 yrs, it has gotten a bit harder to get a replacement. Mazda has started requiring proof of proper oil changes.
And it isn't a free engine. It is a warranty replacement.
https://www.rx8club.com/attachment.p...2&d=1281642601
Old Aug 12, 2010 | 03:09 PM
k just curious about that because my first engine failed at 61k and the replacement engine failed before they even got the car back to me and they tried to make me pay for labor charges replacing it twice... (they didnt get a penny btw)
vapor2
Nov 3, 2020 03:38 PM
Rx808BI
Aug 9, 2015 10:06 AM
digitalmonkey79
Jul 29, 2015 12:09 AM
RX7.9
Jul 20, 2015 12:01 PM
