Help Identify This Part...
Old Jul 30, 2010 | 09:00 AM
Phish806's Avatar
I dont happen to have any pictures of this part but i am in the process of putting hte motor back in the 8. I distinctly remember a small electrical part that i can not find. I am purely going of off memory here so if anyone can tell me what it is and/or what it does i would appreciate it.
What i remember is this: The main wiring harness for the engine is bolted to the top of hte motor via the metal bracket the harness is connected to. I believe that bolted to one of these same holes was a small gray 1/2" by 1/2" box. It had wires coming off it that plugged into the harness via a small black two prong connector (i think) and a ring/washer type attached to it so it could be bolted to the block along with the metal bracket for the harness.
I may have found it in a part book. number N3A1-66-991
After a little searching it says its a condensor. What does it do?
Thanks for hte help guys. and i know its a very bad description.
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
ktec
RX-8 Show and Shine
Oct 1, 2015 11:20 PM
