huge power loss... help!!!
Old Jul 26, 2010 | 03:05 AM
ggavgg's Avatar
2fast4u (ggavgg)
ok so yesterday my buddy put 2 quarts of 10-30w synthetic oil in my car since it was low on oil..and the car drove fine till he returned the car .. when i started driving it.. i felt a major power loss for some reason . when i flored it it felt lyk the car wanted to slowdown over n over... and then every time i rev it a weird sound comes from right where the headers sit.. n it sounds like a lawnmower..it sounds like my headers (greddy) have a crack in it and i can barely hear anything out of the exhaust(also greddy) ...but im not sure if its cracked.. i wanted to no if ayone could help me figure out wht the noise could be and what is causing the power loss.. and if the oil is causing this or not
Old Jul 26, 2010 | 06:36 AM
200.mph's Avatar
FULLY SEMI AUTOMATIC
is your car turbo? ive heard of alot of greddy turbo manifolds are prone to crack. dont lend an 8 to others, it never ends well.
Old Jul 26, 2010 | 06:57 AM
yiksing's Avatar
the giant tastetickles
Did he fool around with your car? Does the car idle normal? What rpm range does problems become more apparent or is it the whole rpm range? Any CELs?
Pretty sure the oil unlikely to have cause this.
Old Jul 26, 2010 | 07:35 AM
Huey52's Avatar
Registered Zoom Zoomer
One of Pettit Racing's tips:
Never let anyone drive your car! Over the years, many customers have come to regret this decision.
Old Jul 26, 2010 | 08:23 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
^..............words to live by!
My car is just about 5 years old now, and one time only did someone else drive it, and that was only into the bay in order to put new rims/tires on and we had a nice long discussion before that happened.
To the OP..............you said you put two qts. in, did it need that much, or did you just dump in two qts? Have you checked it?
Is it possible that you overfilled it and now it's run into the intake, oiled that crap out of the filter and has fouled the MAF?
On another note.....it may not be the oil at all..........could you classify this noise as a helicopter sound? I remember there is/was a thread similar to this, so you might want to search using the word helicopter and see what pops up?
Old Jul 26, 2010 | 09:02 AM
Huey52's Avatar
^ I even transport my 8's rims in my Jeep when getting new tires.
Only once let a friend drive and he curbed two rims.
OP: concur - possibly too much oil and you've now got some excess in the intake accordian and have fouled your MAF. If the MAF is sending a bogus reading to the ECU it can have a significantly [bad] effect on the performance.
Old Jul 26, 2010 | 10:17 AM
Specialpowers's Avatar
Medic-8-'d
Are you sure about that?
I might be wrong but i'd be willing to bet that he knows that he fucked your car, and just doesn't want to admit it. I know this rant doesn't help your situation, but I hate it when people don't own up and take responsibility.
True, it's best not to lend anyone your 8, and i'm sure you've learnt that lesson, but it would be nice to think that your 'friend' is gonna respect your property.
Tell him that to find out what the problem is, you need to know exactly what he was doing when the noise/power loss started, then send his retarded *** a big fat bill when you've managed to get it sorted.
Old Jul 28, 2010 | 03:44 AM
ggavgg's Avatar
2fast4u (ggavgg)
well i got a the exhaust manifold gaskit changed because the old one blew out .. thts y it sounded lyk a lawnmower.. n now i cant figure out what the power loss is from it ... i cant redline .. it has no acceleration...it pushes back when i flor it.. n well i got it checked from buckys n they said i need one new sparkplug and idk if tht could be causing the missfiring n powerloss
Old Jul 28, 2010 | 07:49 PM
It's your CAT
Old Jul 28, 2010 | 09:21 PM
The only person who cam drive my car would be my father. He knows how to drive stick befoere I was even born so I trust his skills. Other than that, no one else, not even my older bro
Old Jul 29, 2010 | 04:37 AM
ggavgg's Avatar
2fast4u (ggavgg)
Originally Posted by Razz1
It's your CAT
the cat is fine .. got tht checked.. did another tune up ... did nothin ...so now im tired of it n im taking it to the dealer tomorrow to figure out wats wrong with it
Old Jul 29, 2010 | 05:24 AM
Rote8's Avatar
My neighbor drove mine and broke the tires loose, she said she wasn't ready for the torque...
Old Jul 29, 2010 | 06:26 AM
DocBeech's Avatar
I drive at Red Line.
your 8 has torque? where is it hiding?
Old Jul 29, 2010 | 12:20 PM
DeViLbOi's Avatar
The devil made me do it
2 quarts is a lot of oil to add to an 8. At 2 quarts your stick is dry and you have to pause in the middle to get all the oil down to the pan before you measure again. Odds are you overfilled it and screwed up your intake. remove your intake back to the SSV and clean it out with a bunch of rags. Then clean off your MAF with contact cleaner and inspect your air filter to make sure it isn't damaged as well. Once you are done check your oil level and drain what is necessary so you don't gum it all up again when it gets hot.
Old Jul 29, 2010 | 04:48 PM
They have to pull it off and look inside. That's the only way to check.
IF the oil was fine when you lent it out... your friend beat the **** out it as you will only loose oil at that rate when you are consistently at Redline on the track.
Old Jul 29, 2010 | 07:06 PM
DocBeech's Avatar
your not driving the car right unless you burn oil so fast taht all you do for an oil change is replace filters:P
Old Jul 29, 2010 | 08:18 PM
ggavgg's Avatar
2fast4u (ggavgg)
its my cat.. got it taken off and actually checked.. n well.. now im wondering if i should get a midpipe delete the cat???
Old Jul 29, 2010 | 08:26 PM
alnielsen's Avatar
The cat has a 8yr/80K mile warranty. If it is within this period, get it replaced. Then get the midpipe and store the cat for a rainy day.
Old Jul 29, 2010 | 09:44 PM
DocBeech's Avatar
you mean the annual inspection?
Old Jul 29, 2010 | 09:45 PM
ggavgg's Avatar
2fast4u (ggavgg)
i have a aftermarket headers would tht matter??
Old Jul 29, 2010 | 10:18 PM
Renesis07's Avatar
Vtak just kicked in yo!!
The only thing that matters is the part of your exhaust that actually yields decent HP gains still hasnt been replace ;-)
Get a midpipe and store the cat for emissions. I just busted my cat out of storage this month to get the test done.
Do you have an accessport or anything of that nature? If not, expect a CEL with a midpipe, unless you go with a supercat of some sort...
Old Jul 29, 2010 | 11:20 PM
ggavgg's Avatar
2fast4u (ggavgg)
i have mufflers and headers.. thts it... so u think they should be able to replace it.. and welll im at 79333 miles..
Old Jul 30, 2010 | 01:27 AM
alnielsen's Avatar
The cat is warrantied by federal law. Yes, they should replace it. However, some dealers won't unless there is a code in the ecu.
Old Jul 30, 2010 | 02:05 AM
ggavgg's Avatar
2fast4u (ggavgg)
the only code i have is for the upstream o2 sensor... n the car is rebuild but thts not wat it says on the title
Old Jul 30, 2010 | 11:18 AM
Renesis07's Avatar
Your car has a 80K mile emissions warranty, if your cat is toasted, they WILL cover it.
RevMeHarder
Jun 1, 2026 02:30 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
Trekk
12
Sep 25, 2015 03:08 PM
