View Full Version : Engine Light and oil
00RM125 07-24-2010, 04:22 PM so i just got a new motor put in my 2004 Rx8. when i drive at steady or high rpms the engine light blinks and has a code that reads misfire cylinder two, could this be from having crappy gas in it or something more? cause the car runs fine and isn't blowing smoke or anything noticeably bad.
also i see a lot of opinions on what oil to use. and was wonder if i should go with 10W20 or 5W30, and is there a brand i should go with? i would like to use either mobile one, or royal purple, what do you's think? I'm from ct so it gets very cold in winter. and also very hot in summer, cause i heard that the weather effects what oil to use. so any help/opinions would be appreciated.
~~~~~PROBLEM SOLVED~~~~~
ronx8 07-24-2010, 04:33 PM misfire usually means coils, plugs, n wires.
not sure if they reuse those when replacing the engine.
stinksause 07-24-2010, 10:28 PM check coils plugs and wires ... in the worst case, a misfire can cost you a motor
I used Castrol Gtx .... 10w30 in summer .... 5 w 20 in winter and I change every 2k to 3k miles
00RM125 07-25-2010, 10:47 AM ok i have 10W20 gtx semi synthetic in it now so good to hear im not doing everything wrong. and wih the misfire..i already lost one engine. so ill get wires for it tomarrow and see what happens. but will seafoam help get rid of the shit in the gas tank? or at least help burn it off?
FastFreddy61 07-25-2010, 01:21 PM I read in here recently that a particular synthetic oil ,not to use ,is Mobil 1.As best as I can remember.But dont quote me.
stinksause 07-26-2010, 12:00 AM shit in the gas tank? How do you mean? Seafoam is primarily used as a de-carbon method
00RM125 07-26-2010, 12:43 PM well the car sat for about 4-5 months. and i didnt kno if that would make the gas in it go bad or stail. so i thought that seafoam would help burn it off like it does with the carbon build up.
terch1 07-26-2010, 01:10 PM Had the same problem with mine when I had my new engine installed. Reset the eccentric shaft position sensor.
00RM125 07-26-2010, 06:25 PM not to sound like a noob...but where would this censor be located?
terch1 07-26-2010, 06:48 PM Not sure exactly but the location isn't important. (I believe it is located right near the main crank) There is a procedure to reset the sensor. I believe you turn the key to the on position and pump the breaks quickly 20 times until the check engine light blinks. Anyways its something like that. Do a little research and you will find the procedure. Its been a while since I've done it myself.
00RM125 07-26-2010, 08:10 PM thanks man i found that procedure. but the light now comes on and off randomly.. lol so im gonna try changing the coils and wires see what happens. but that did get it to go off for a little while
fastlaneracing 07-27-2010, 01:08 AM Clean the Ecc. Sensor, might help.
00RM125 07-27-2010, 08:37 AM i cant find the damn thing. lmao any pics or something to help me locate it? but thanks for all your's help so far
TheWulf 07-27-2010, 08:58 AM I read in here recently that a particular synthetic oil ,not to use ,is Mobil 1.As best as I can remember.But dont quote me.
Mobil 1 is a great oil. Though go read the oil threads for general info on synthetics.
From underneath the car, it's right in front of the oil pan next to the e-shaft pulley (the bigger one).
You can also do it from the top if you take off your intake (or if you have the MS/AEM CAI there's enough room to get to it.). It's between the e-shaft pulley and the A/C compressor pulley all the way at the bottom. I find it's easier from underneath the car though.
Specialpowers 07-27-2010, 10:09 AM I had a bad sensor, and it only caused problems when starting. It also threw up an ecc. sensor error code, rather than a mis-fire code. I understand that your problem could be the sensor, but I think its far more likely to be (as already mentioned) bad coils, plugs, or leads.
00RM125 07-27-2010, 01:49 PM also another few questions.. does the numbers on the coils matter? cause mine went 1-3-2-4 or something close, and i replaced them with others from my other motor but in no order...would this cause a problem if the numbers arent in order or in a certain pattern? and does the check engine light have to b reset to go off? or when the problem is fixed it will go off itself?..
stinksause 07-27-2010, 02:24 PM here is the sensor
http://www.rx8club.com/attachment.php?attachmentid=118746&d=1207803002
image taken from here http://www.rx8club.com/showthread.php?t=142852&highlight=DIY+seafoam
stinksause 07-27-2010, 02:43 PM as for your coils ... make sure you have the correct signal going to the correct spark plug ... otherwise you could be rebuilding pretty soon ... I do not think that the Coils physically differ from each other though ... what is the exact CEL you are getting?
00RM125 07-27-2010, 03:51 PM solid engine light and blinks randomly. also thank you for that picture it helped tonss..but the coils will have to go 1-2-3-4 then? cause when i got it they werent in order of 1234 cause i had two 3's..im so confused lmao
stinksause 07-27-2010, 04:41 PM You are confusing me ... what numbers are you talking about?
Blinking CEL means misfire ... ur engine is in danger ... what is the code you are getting?
terch1 07-27-2010, 05:12 PM The following link should help you out.
http://www.rx8club.com/showthread.php?t=138419
00RM125 07-27-2010, 06:28 PM i dont know the code. the kid just hooked it up to a computer and said it was saying misfire on cylinder two. and on the top or the spark plug coils they have numbers 1-2-3-4... i dont know if they have to go in order or not
What matters is that each coil pack is feeding the correct spark plug.
Check that the wires run exactly like this:
http://i32.photobucket.com/albums/d37/Jedi54/coils.jpg
00RM125 07-27-2010, 10:33 PM that's exactly howthey are...i reset the Eccentric shaft censor today and diconnected the battery along with the 21x brake pedal reset and its been fine. so i think you guys have helped my dilemma!! i will let you know if it goes back on tomarrow or if other problems occur, but THANK YOU ALL for your understanding and willingness to help, it is much appreciated and very helpful!!
00RM125 07-28-2010, 02:57 PM bad news ppl =[ lol i drove it today to see if the light would come on and the light is blinking at random rpm's again but not staying lit like last time. so i dont know what it could be and im getting very frustrated with the car. any other opinions on what it could be? cars still runs/starts and idles fine
RIWWP 07-28-2010, 03:03 PM You might be losing your cat. I had misfires from cat failure.
If you feel a power loss under high load, and it keeps getting worse, then this will confirm it.
stinksause 07-28-2010, 03:53 PM get this if it is your cat http://www.racingbeat.com/FRmazda4.htm ;)
although how would clogged cat cause a misfire code?
Well i seem to have the same problem, my engine light comes on when i'm doing around 30 / 40 mph. Brought it to mazda on tuesday and they still can't find anything wrong with it.. Another issue is the darn tire pressue montor light. Seems like it has a mind of its own.. Tire pressure is good and tires are new. So they can't figuer that out neither... Any suggestions ?
00RM125 08-07-2010, 09:49 AM i feel no loss of power what so ever and my cat only have about 2-3k on it. so i dont think thats the issue. but i will look into it if i cant get anything else to work.
http://www.rx8club.com/showthread.php?t=202411
created another post. and some other opinions are on there if u need help like me.
alexvikings05 10-05-2010, 09:24 PM when i first purchased my 8 i was told that i can only use reg. motor oil. i've been reading some of ya comments and it seems like ya use synthetic. would i have a problem using synthetic?
Before you get flamed to hell and back: this topic has been beaten to death here, there are stickies on the subject. Basically, read those and decide for yourself... there is no conclusive answer.
RIWWP 10-06-2010, 12:11 PM Oil is classified under "Religious War" here on the forums. Tread carefully lest you lose the pants you came in on. :)
