A/C Refrigerant line replacement???
Old Jul 24, 2010 | 09:13 AM
wowo76's Avatar
NJ A/C Refrigerant line replacement???
I've found a hole in one of my AC lines that runs along the passenger side from the firewall to the pipe connected to the condenser. Has anyone ever replaced this before with an OEM replacement and how difficult was it? It it possible to use refrigerant rated hosing to replace the metal line?
Thoughts anyone?
Thanks in advance.
Old Jul 24, 2010 | 02:00 PM
VashGS's Avatar
Zoom Zoom Addict
If it's in the line replace. You can use sealer for like o-rings but this prob not a good idea. Try to find salvage if you want to save cash otherwise $$$. You need to evac, replace hose & o-rings (properly lubed with o-ring lube), torque to spec. Recharge.
Old Jul 24, 2010 | 04:36 PM
EDZRIDE's Avatar
2005 White GT
It's possible but I don't recommend it, too many potential problems down the road; perhaps you could get it welded.
Old Jul 24, 2010 | 08:15 PM
DocBeech's Avatar
I drive at Red Line.
just find yourself a totaled car at a junk yard, or buy the proper parts and do it correctly. It will give you a chance to insulate the line, like the factory should have, and have a better running ac.
Old Jul 25, 2010 | 01:14 PM
604Veilside8's Avatar
if you have a leak you will have lost refrigerant, and you probably need some to be charged back into the system, otherwise the system wont work quite right.. you'd need to recover the refrigerant, and replace the pipe and re-charge it.
Old Aug 4, 2010 | 05:46 PM
shadycrew31's Avatar
WENTGERMAN
You need a specialty tool to remove that line. Download a copy of the FSM and look under page 17 in the HVAC section. I cant access the online manual at the moment. otherwise I would have posted that for you.
Good luck.
Old Aug 4, 2010 | 09:00 PM
wowo76's Avatar
NJ
Good luck.
You are absolutely correct. I took a quick look at that line a few days ago and was like . I have the FSM and saw the tool that I need...I'm going to need to make a trip to the dealer sooner than I thought.
Thanks shady
Old Aug 5, 2010 | 12:20 AM
WENTGERMAN
Yeap no worries! I would check with Partsgroup.com or ebay for a used refrigerant line.
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
mesaboogie
Aug 7, 2015 10:48 AM
mazdaverx7
Jul 21, 2015 07:31 PM
