Series I Do It Yourself Forum Wanna save some coin or time/money in the shop? Read up on Do-It-Yourself custom mods and repairs & post your own here.
DIY: Replace Passenger side airbag cover thats splitting for $150.
Old Jul 21, 2010 | 03:22 PM
Rocketman1976's Avatar
Tailgaters beware
About a year ago my passenger side dash cover started to split right at the seams where the airbag would burst through.
The dealer wouldn't cover it in warranty because I had an accident a year earlier and they said that the Mazda rep said that the car probably twisted enough to cause a strain on the material that it eventually began to tear. The dealer told me the part is $550 and the labor would be $150 so $700 total to replace a split piece of dash!
I decided to find a used dash panel (with airbag attached because they are riveted on), and I found a few on Ebay at junk yards for between $180-400.
Be sure that when you are searching that there is a picture of the piece because after zooming in on some pictures, I noticed a few of them had the same split mine did.
I actually made a OBO offer on one that wanted $200 and they accepted $75. Luckily I contacted the seller before making payment, because he wasn't supplying the dash cover because they told me it was damaged during removal.
After a few weeks of searching I found one that said $189.00 Or Best Offer, so I made few offers until he accepted $105 plus $35 for shipping. This was a great deal since the one in his picture looked flawless except for a little dirt. The item that arrived was exactly the one in the picture.
Here is some pictures and info on the easy removal and replacement.
The picture below shows the split in the material.
Attached Thumbnails DIY: Replace Passenger side airbag cover thats splitting for 0.-0.jpg
Old Jul 21, 2010 | 03:40 PM
Tailgaters beware
Step 1
Before you even start on the project, you need to first remove the negative terminal on your battery this way you don't cause any kind of power spike when disconnecting or connecting your new and old airbags, this is to avoid deploying one by accident.
Next thing you need to do is open your glove box and look on the right hand side outside of the actual box.
There is a small piston that slows the opening of the box.
Pull the loop on the end of the piston off the plastic **** on the side of the glove box.
Be careful with it because it break very easily (I broke mine).
Even if you do break it you glove box will still be fine, it will just kind of slam open if there is a lot of stuff in it.
Attached Thumbnails DIY: Replace Passenger side airbag cover thats splitting for 0.-1.jpg
Old Jul 21, 2010 | 03:45 PM
Tailgaters beware
Step 2
Next you need to drop the glove box to access the 2 bolts under the air bag, and the airbag connector.
To drop the glove box you will need push in on the sides of the box where the red arrows are.
You don't need to apply much pressure at all, it just bends slightly to pull in the stoppers and allow the box to drop down all the way.
After dropping it you can remove it entirely if you want, but with it just hanging down there was plenty of room to finish the removal and install.
Attached Thumbnails DIY: Replace Passenger side airbag cover thats splitting for 0.-2.jpg
Old Jul 21, 2010 | 04:00 PM
Tailgaters beware
Next use a set of needle nose pliers to squeeze this clip and push it out of the hole.
Make sure your car's battery is disconnected before disconnecting the airbag.
After you get the Airbag connector free from the bracket you can disconnect it.
It's better to disconnect this connector before the next step because it gives you better access to the bolts holding in the airbag and dash cover.
Attached Thumbnails DIY: Replace Passenger side airbag cover thats splitting for 0.-3.jpg
Old Jul 21, 2010 | 04:07 PM
Tailgaters beware
Here are the only two bolts that actually need to be removed in order to remove the entire cover and airbag assembly
If you disconnected the airbag plug connector it should be very easy to remove the bolts.
Attached Thumbnails DIY: Replace Passenger side airbag cover thats splitting for 0.-4.jpg
Old Jul 21, 2010 | 04:19 PM
Tailgaters beware
Once the two bolts are removed, you can begin to pull up on the edges of the dash panel. The only thing holding it in now is 8 clips around the edge of the panel. The clips release when you pull up on the dash.
I started by pulling up on the edge right where the glove box met with the dash.
I removed the A/C vent and the defroster vent to give me more area to pull up on, but I don't think it is necessary.
The A/C vent comes out by just pulling evenly on two sides of it by reaching your fingers inside of the cup, and the defrost just pulls forward and up.
Attached Thumbnails DIY: Replace Passenger side airbag cover thats splitting for 0.-5.jpg   DIY: Replace Passenger side airbag cover thats splitting for 0.-6.jpg
Old Jul 21, 2010 | 04:23 PM
Tailgaters beware
The Final Product.
When putting the new dash panel in just be sure you feed the airbag line through before you push the new dash into place securing the clips, otherwise you may pinch the connector cable.
Good as new and I saved $550!
I can't believe the dealer wanted $150 to do the install that only took about 30 mins for a first timer.
Attached Thumbnails DIY: Replace Passenger side airbag cover thats splitting for 0.-7.jpg
Old Jul 13, 2011 | 05:25 AM
Blacknightz's Avatar
Oh my... u made it look and sound easy!!!
Good job and the work is flawless...
2 Thumbs up !!!
Old Jul 14, 2011 | 01:06 AM
monchie's Avatar
I HATE SPEEDBUMPS!
Thanks for sharing your expertise.
Old Jul 14, 2011 | 09:06 AM
Grungepup's Avatar
Oilfield trash
Thanks for thanking for sharing
Old Jul 14, 2011 | 09:42 AM
Z0oMzo0m's Avatar
not as bad as i thought the project was going to be! cool thanks, il will have to do mine some time in the future as well.
Old Jul 15, 2011 | 01:32 AM
monchie's Avatar
I HATE SPEEDBUMPS!
Thanks for responding about my post, thank you.
Old Jul 17, 2011 | 05:01 AM
ASH8's Avatar
Super Moderator
Great job mate!!
Old Aug 10, 2011 | 05:01 PM
Tailgaters beware
No problem everyone.
I'm just an occasional DIY backyard mechanic and I appreciate when others share so I try to give back when I can.
Old Sep 17, 2011 | 01:52 PM
drasticRx8's Avatar
I had to change my airbag too and this DIY helped alot,everything was flawless. thanks!
Old Sep 17, 2011 | 05:25 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Well, mine's on order and I was gonna wing it, but Ash8 pointed me over to this thread, so why wing it when there is some sort of a guide.
I know how to get the glove box out but it's nice to see where the damn clips are......that's for sure.
Old Sep 28, 2011 | 04:45 PM
cornholio135's Avatar
SARX
Originally Posted by Rocketman1976
...I decided to find a used dash panel (with airbag attached because they are riveted on)...
Actually you can unbolt the airbag....
I just removed mine and took it to an upholstery shop to have it recovered in textured vinyl... will post pics when I get it back...
thanks for the DIY made it easy to remove this...
Old Sep 30, 2011 | 11:47 AM
SARX
Ok got my dash back from the upholstery shop..came out perfect
$75
Old Sep 30, 2011 | 11:56 AM
Z0oMzo0m's Avatar
looks good, but does it mismatch with other dash pieces now? picture looks like it stands out. no?
Old Sep 30, 2011 | 12:03 PM
wrightcomputing's Avatar
Made in England
Thanks for the DIY, I will need to do mine at some point. I have a feeling that I would rather wait till I want to sell the car because I live in FLorida so if I change it the sun will just eat through the new one. I do like tcornholio135's idea of getting it recoated or upholstered.
Old Sep 30, 2011 | 12:06 PM
SARX
blends perfectly....
Well I live outside of San Antonio in sunny south texas... we will see how it holds up... since it is vinyl and not the material the dash is made of I anticipate it not cracking...
Also since it is vinyl, if the air bag does deploy it should have no problem ripping thru (I have seen the passenger air bag in other vehicles break the windshield)
And thank GOD i do not have to look at that cracked dash anymore...
Old Sep 30, 2011 | 02:11 PM
Made in England
My friend had and astra and when his airbags deployed it smashed the windscreen. Not that it matters because if you airbags deploy you have generally totalled the car.
I also hate looking at the crack.
Old Oct 1, 2011 | 12:15 PM
did u consider doing it in suede instead>?
Old Oct 1, 2011 | 09:56 PM
SARX
Uuh no.. But I'm now considering having the driver side piece covered in the same material...
Old Oct 2, 2011 | 10:10 AM
Ur textured vinyl is it the low grade or the high grade?
It should last longer than real leather yes?
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
