Koyo radiator
Old Jul 20, 2010 | 11:08 AM
AND1's Avatar
Koyo radiator
Whats better a koyo or mishimoto ? Also partsgeek.com has koyo for under $200.. Has anyone ever bought from them ? Casue i see in my area they running for like mid $300.
Old Jul 20, 2010 | 11:16 AM
IronTanuki's Avatar
I can't speak from personal experience but the general consensus from all the threads I've read is that the stock radiator is better than either of those. If you want to upgrade your radiator get a Griffin unit from BHR or a Ron Davis one from Mazmart.
Old Jul 21, 2010 | 07:10 PM
AND1's Avatar
So i ended up getting a mishimoto.. At this performance shop around my way called japtrix.. See how it goes once i really take it for a ride.. But my radiator symbol still keeps on popping up.. Wondr if my sensor is dirty ? Not over heating or anything.. Also have my ( t.p.s ) flashing no air leaks on tires just got all new tires on saturday..
Old Jul 21, 2010 | 07:17 PM
VashGS's Avatar
Zoom Zoom Addict
Sensor get's bent. Cause Mazda let oem run too hot and a materials defect. Want a recall on that? too bad lol.. just stare at the Crown Royal time to buy a bottle icon...
Old Jul 22, 2010 | 08:18 AM
AND1's Avatar
Originally Posted by vashgs
sensor get's bent. Cause mazda let oem run too hot and a materials defect. Want a recall on that? Too bad lol.. Just stare at the crown royal time to buy a bottle icon...
im just gonna do like everyone else and unplug it... The bottle is fine. No leaks anywhere... But i sure could have a drink of crown royal...
Old Jul 22, 2010 | 10:26 AM
otakurx's Avatar
Rotorheaded Geek
I haven't had any issues with my Koyo. I have the fans adjust to kick in at 188 and 190 with full speed at 195 and it never goes over 200.
Old May 25, 2016 | 02:41 PM
Jmanie9515's Avatar
Originally Posted by nycgps
Many people treat Koyo V series rad as "cools better than stock" replacement, which is wrong. V series is intended for "OE replacement" only.
As their "up to 30% better cooling than stock" its just their company's slogan, it doesnt mean everything they sell is 30% better than stock.
I personally never had a problem with Koyo V-Series radiator, I replaced it simply because I wanna try new stuff. and many people failed to remove/reinstall the foam piece to cover the side of the radiator, which results in crappy cooling.
BHR/Griffin and Mazmart/RonDavis are both good stuff.
Im using Knight Sports Radiator now made by Koyo, at 53mm, its the biggest Radiator for this car. (I don't think anybody here will like the price though)
So you would say the koyo is a good buy? OEM quality performance, ALL aluminum, worth the buy for someone who doesn't go to the tracks and just drives fast in hot temps?
Old May 29, 2016 | 08:46 AM
Steve Dallas's Avatar
Water Foul
It depends on your goals. If your OEM radiator is still good, just keep it. The standard Koyo has the same performance characteristics, but may actually perform to a lower standard, because it doesn't have the foam attachments. (You have to make them yourself.)
If yours is failing or has failed, and you want to ditch the plastic bits to make sure it never happens again, the Koyo makes some sense, although an OEM style radiator only costs around $90 and should last another 10 years.
For my money, if I were replacing it anyway, I would buy a radiator with a thicker core for better cooling. I have a Koyo HH Series 48mm and like it. It has dropped my average track temp by about 10 degrees, and gives me faster recovery times.
Old May 29, 2016 | 11:10 AM
Jmanie9515's Avatar
The plastic on my original cracked so I'm just looking for a replacement. But I went with the OEM replacement Koyo which is made out of plastic as well. I also bought the re-medy thermostat. But I don't do any track driving. I just like to drive fast and live in the high temps of Louisiana.
05rx8mazda
Nov 28, 2015 09:42 AM
olyrx7
Oct 26, 2015 09:23 AM
projectr13b
Rotary Swaps
Sep 21, 2015 04:52 PM
Irvinb16
Sep 11, 2015 10:27 PM
