LSD parts available?
Old Jul 15, 2010 | 07:05 AM
pjtj2's Avatar
I recently bought an 04 LSD. I thought I'd check it before installation. Upon disassembly I noted some wear on the two clutch plates. It seems Mazda treats the LSD as a part not an assembly. Does anyone know of a source for the plates? Thanks
Old Jul 15, 2010 | 04:58 PM
I have a complete low mileage OE LSD I'll sell you, swapped it out with an aftermarket one, maybe 5000 miles tops on it
Old Jul 15, 2010 | 06:46 PM
jasonrxeight's Avatar
I thought there were no clutch in OEM LSD?
Old Jul 15, 2010 | 07:42 PM
pjtj2's Avatar
lsd
There are two friction surfaces per axle. One is machined into the splined hub that mates to the axle, the other is a ring shaped clutch plate made of a softer metal which fits loosely into the diff carrier. (See attached photos). Springs fitted between the two hubs apply pressure holding the hub and plate together.It's a relatively simple design and could easily be rebuilt if the parts were available Team RX8, what kinda money you looking for?
Attached Thumbnails LSD parts available?-lsd-001.jpg   LSD parts available?-lsd-002.jpg
Old Jul 19, 2010 | 07:09 AM
Not much, lmk via pm or email, just happened upon the thread again ...
RXFEVER
Sep 11, 2016 02:51 PM
RXFEVER
West RX-8 Forum
Sep 28, 2015 08:30 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
Rupanrx
Sep 4, 2015 06:44 AM
