Car has rough idle
Old Jul 9, 2010 | 08:42 PM
renesis13t's Avatar
AZ Car has rough idle
My car has been idling rough when it sits for more than a day but after 5 to 10 sec tops it idles normal....I have had no problems or hesitation while driving. It just seems odd to me because if i have driven the car at any point during a 24hr period it always starts and idles fine but if it sits for longer than one day it refuses to idle correctly this has been going on for a few weeks now, any ideas or help would be great
Old Jul 9, 2010 | 09:28 PM
Winning 8's Avatar
Hot Pit
new battery, spark plugs, MAF cleaning......
Old Jul 9, 2010 | 10:39 PM
renesis13t's Avatar
I have a new battery and new plugs I guess i can clean the maf the air filter is new also , and then get new plug wires
Old Jul 12, 2010 | 03:03 PM
anti-mike's Avatar
Having the same problem...
Also had a flashing CEL during the rough idle, which went away when the car began idling normally.
I dont think it has anything to do with MAF, battery or plugs, since it only happens when the car is first started, and goes away after a while. A dirty MAF or failing plugs/wires would be problematic all the time.
Old Jul 13, 2010 | 01:22 PM
renesis13t's Avatar
Well I cleaned my MAF put it back in it has been starting but the idle seems low now sigh...like barely over 500 rpm then it will slowly climb to 700 but i have yet to let it sit for a day to see if it will start normal after sitting...new plug wires still on order and considering upgrading my coils but Idk
Old Jul 19, 2010 | 11:29 AM
anti-mike's Avatar
Just happened to me again this morning, car sat all weekend, ran rough for about 30 seconds with the SES light flashing intermittently. I wonder if its debris in the gas tank clogging the fuel filter. That would explain the lean SES code I've seen in similar posts (haven't had mine read yet to be sure).
Old Jul 20, 2010 | 02:23 AM
renesis13t's Avatar
Well i cleaned my maf and I haven't had any bad starts since but I have this feeling it is just a band-aid I also haven't let my car sit for more than a day since tho so i cant be sure
Old Mar 31, 2011 | 03:00 PM
anti-mike's Avatar
Did you ever figure out what this was?
9krpmrx8
Nov 5, 2015 11:45 PM
Quato_jr
Aug 4, 2015 09:22 AM
digitalmonkey79
Jul 29, 2015 12:09 AM
dbarber
Jul 25, 2015 01:34 PM
netrovers
Jul 20, 2015 03:32 AM
