compression numbers - your opinions?
Old Jul 7, 2010 | 05:39 PM
tuj's Avatar
tuj
Question compression numbers - your opinions?
When I first got my car, this was the compression (sorry I do not know the RPM they tested at, I assume ~260):
f: 7.8, 7.4, 8.1
r: 7.2, 7.6, 8.0
Now I am at 54k miles on the car and just got a compression test done again, this time *with* the RPMs. At 267 rpm:
f: 6.9, 6.7, 6.6
r: 6.4, 6.4, 6.3
Thoughts on how the engine is aging? I don't really know how good or bad these numbers are, so help me out please. I'm surprised there was that much drop. The dealer told me that anything over 7 was 'like new'.... Not sure I buy that....
Old Jul 7, 2010 | 06:17 PM
Jon316G's Avatar
Grasshopper
I had to convert this to PSI for me to visualize easier
Since you didn't know the RPM for the first test, I'll just use the 267 from the 2nd test (unless you upgraded the starter since).
f: 7.8, 7.4, 8.1
r: 7.2, 7.6, 8.0
Converted to PSI (rounded):
F: 111, 105, 115
R: 102, 108, 114
Normalized to 250rpm:
F: 110, 104, 115
R: 101, 107, 113
And this is your latest compression numbers:
f: 6.9, 6.7, 6.6
r: 6.4, 6.4, 6.3
F: 98, 95, 94
R: 91, 91, 90
F: 97, 94, 93
R: 90, 90, 92
Standard: 120psi @ 250rpm
Minimum: 98.6psi @ 250rpm
Looks like its time for a new engine!
Old Jul 7, 2010 | 06:20 PM
tuj's Avatar
tuj
wow you are kidding me....I'm on the way out aren't I? 'Normal' wear? Or something perhaps worse?
Thank you for converting and normalizing the numbers, all I got were two camera photo printouts of the tester from the dealer.
I bought my car in late 2004, am I still under the warranty? My dealer told me these numbers were "fine", so how do I go about telling him otherwise (btw, I had to explain what a 'face' of a rotor was to the manager....sigh, and this is Mazda?)
Old Jul 7, 2010 | 08:05 PM
Jon316G's Avatar
Grasshopper
The car will likely still run fine... its just under Mazda's minimum tolerance.
The engine core is covered for 8yr/100K miles
You can keep driving it until you notice power loss and/or hard starts (or you're close to warranty end).
Then worry about that argument... which the numbers will probably be less and they may not argue with the readout.
But you can always ask them why they say its fine when Mazda's tolerance is 8.5 standard and 6.9 minimum.
Old Jul 8, 2010 | 06:28 AM
tuj's Avatar
tuj
Any theories as to how this happened? I have always kept the car full of oil, I have always let it warm up before taking it above 4k rpms. I've done all my oil changes on or ahead of schedule.
gwailo
May 14, 2024 06:57 AM
05rx8mazda
Nov 28, 2015 09:42 AM
Trinads
Sep 10, 2015 01:05 PM
Tsurugi
Sep 7, 2015 08:27 PM
