Idleling low
Old Jul 5, 2010 | 07:35 AM
SilkyJohnson's Avatar
Idleling low
Did my coils, plugs, and wires and on the first start up she run fine, better than ever. It's been about a week and she is idleing at about 750 RPM.. any ideas?
Old Jul 5, 2010 | 08:52 AM
drderekrx8's Avatar
My car always id..les around 750-800 .... i thought it was normal....... i havnt changed coils recently though.......
Old Jul 5, 2010 | 11:56 AM
I pulled on base today and she damn near died on me...
Old Jul 5, 2010 | 01:44 PM
Bullitt's Avatar
In the pipe five by five.
I have the same issue. Stalled a couple of times.
Old Jul 6, 2010 | 04:31 PM
Compression test time.
Old Jul 6, 2010 | 09:54 PM
yiksing's Avatar
the giant tastetickles
Mine idle at 750 - 800 rpm as well since day 1
Old Jul 6, 2010 | 10:17 PM
jasonrxeight's Avatar
mine idles at 800, but when the car is moving, it goes up to 1100.
Old Jul 6, 2010 | 10:37 PM
maskedferret's Avatar
Oooh, shiny!
ditto
Old Jul 6, 2010 | 10:59 PM
Originally Posted by maskedferret
ditto
probably for less engine braking?
Old Jul 7, 2010 | 12:34 AM
staticlag's Avatar
The Professor
Low idle & stalling is probably a vacuum leak. Inspect all the vacuum hoses.
Old Jul 7, 2010 | 12:47 AM
Ryan2008's Avatar
Registered Paratrooper
That idle is normal, why it's dying out on you I'm not sure. But my car has always idled 750-800 rpm.
Ryan
Old Jul 7, 2010 | 09:27 AM
Could be a vacuum leak, just check everything, clean your MAF, air filter, etc. Both of my previous engines that died had these symptoms before compression tests.
Old Jul 8, 2010 | 01:15 AM
and what was determined after the compression test?
Old Jul 8, 2010 | 09:33 AM
They failed, that is why the engines were replaced.
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Michael Bryant
Oct 12, 2015 03:07 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
xAgyex
Sep 28, 2015 08:54 AM
