When pushing on the gas, a second or two goes by before the car launches.
Old Jul 3, 2010 | 05:12 PM
msorokin1's Avatar
I don't really know which thread to put this in, but i have a question. Is the rx8 supposed to do this?: you push on the pedal pretty far, then a second or two goes by, and then the car launches with speed? My mothers nissan altima is different, as soon as you push the pedal, the car takes off, and it's completely stock. So im wondering, is there anything i can do to the rx8 so as soon as i push the pedal it takes off without that little moments hesitation?
Old Jul 3, 2010 | 05:14 PM
Z0oMzo0m's Avatar
HUH??
cant believe i post to this..
auto?manual?
Old Jul 3, 2010 | 07:16 PM
msorokin1's Avatar
2004 mazda rx8 automati/manual
Old Jul 3, 2010 | 07:19 PM
Z0oMzo0m's Avatar
sell it, its a defect..
Old Jul 3, 2010 | 07:21 PM
msorokin1's Avatar
really? thats an extreme answer. theres nothing i can do to it to fix it?
Old Jul 3, 2010 | 07:23 PM
Jon316G's Avatar
Grasshopper
Just to clarify... when you press on the gas pedal, does the car move right away or are you saying there is a delay from the time you press the pedal to the time the car moves?
Old Jul 3, 2010 | 07:27 PM
msorokin1's Avatar
the car moves as soon as i push the pedal, let me clarify.
on the rx8. when i give it alot of gas, it accelerates a little bit, then the real power kicks in a second or two later.
on my mothers nissan, when i give it alot of gas the real power kicks in instantly.
it seems like the rx8 has a safety feature to not allow the driver to accelerate too fast or something.
Old Jul 3, 2010 | 07:31 PM
Jon316G's Avatar
Grasshopper
1) This isn't a Nissan so stop comparing
2) At what RPM are you trying to accelerate quickly? If its under 4K forget about "quick" acceleration.
3) If there is a lag above 4K RPM, many factors such as clogged cat, ignition components, dirty MAF, or intake leak can cause this.
Old Jul 3, 2010 | 07:33 PM
msorokin1's Avatar
ok its number two. so thats normal then? so if i wanted to get max acceleration of a stop how would i do that?
Old Jul 3, 2010 | 07:38 PM
Jon316G's Avatar
Grasshopper
Stay in 1st gear longer... shift at higher RPM.
I've never driving a 4-port auto before so I don't know the "sweet spot" shift points.
But on my manual I stay in 1st until 6-7K rpm and shift quickly before the RPMs drop below 4K.
And I'm not sure how our "4K rpm launch" works on the auto...
Old Jul 3, 2010 | 07:40 PM
msorokin1's Avatar
yeah on a automatic/manual reline begins at 7.5k
Old Jul 3, 2010 | 07:44 PM
Jon316G's Avatar
Grasshopper
Just play with the different RPM ranges and keep the shifting at higher RPMs.
Redline does not mean you'll get the most power there, so don't judge that as your shift point.
Sorry to say, but the 4-port auto engine is the lowest powered... so you're kinda stuck there.
Old Jul 3, 2010 | 11:42 PM
msorokin1's Avatar
yeahhh.i wish i went with the manual. it was 7k more though. mine only cost me 10k
Old Jul 3, 2010 | 11:44 PM
Jon316G's Avatar
Grasshopper
Well then I won't mention that manuals go for 10-12K nowadays... oh wait, I just did
Old Jul 4, 2010 | 12:13 PM
msorokin1's Avatar
hahaha so im assuming taking it to the shop and getting the transmission changed to manual would cost a **** ton
Old Jul 4, 2010 | 12:16 PM
Jon316G's Avatar
Grasshopper
Not to mention it won't help with "performance gains" the MTs have... you're still restricted by the 4-port motor!
Old Jul 5, 2010 | 12:05 AM
tofu_box's Avatar
mso
My recommendation for a "launch"
Foot on Brake, Keep the RPM at around 2.5k, that should give you a slighter better launch!
Skyl3r
Dec 2, 2019 04:51 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Bamaham
Jul 23, 2015 08:08 AM
dmengel
Jul 18, 2015 09:35 AM
Belalnabi
Jul 17, 2015 07:48 PM
