Advance Keyless Entry Question
Old Jun 22, 2010 | 12:31 AM
Rotary-RX8's Avatar
Girls who drive stick FTW
I searched but the specific question im looking for was not found. I have an 06 and i have the advance keyless entry. Now in the manual, it says that in the case that the battery in the remote dies, you can remove the emergency key and unlock and start the car. I tried this, and the key isnt unlocking my door. Its able to lock it and openn the trunk but when i turn counterclockwise it does not unlock the door. When i turn clockwise it locks the car. What am i doing wrong here ?!
Im just asking this in the case of an emergency. I wont even be able to get in my car !!!
thanks in advance
Old Jun 22, 2010 | 09:31 AM
Snrub's Avatar
That's odd, I've had problems with my "advanced" key and have been using the emergency key exclusively for almost a year. The black plastic piece should be sticking up when you put it in the door. It is possible your key is bent or something?
Old Jun 22, 2010 | 09:38 AM
VashGS's Avatar
Zoom Zoom Addict
The door needs the RFID key too. hold the remote close to the hole when you try it with the plastic key. The RFID chip does not need power
it get's scanned by the car.
Old Jun 22, 2010 | 11:18 AM
Rotary-RX8's Avatar
I just went outside to try it. And stilll nothing . I took the key out (with the battery still inside the remote), and tried unlocking the door. THe key should still be work even if the batterys working no ? THe key doesnt even turn. I tried flipping the key. It wont turn !! It turns to lock the car but not unlocking it. I help the remote like 1 CM away from the key hole. Nothing !!!
Help !! IM really scared if i ever have to go through this situation. I wont even be able to getn my car.
Old Jun 22, 2010 | 12:01 PM
paulmasoner's Avatar
Asshole for hire
theres not a com problem since you can lock the door with it and get in the trunk. gotta be a physical thing
Old Jan 23, 2011 | 04:27 AM
maitre's Avatar
Registered Sexy Offender
Another thread mentioned the same problem, fix seemed to be to just try lubing the lock. Classic Mazda issue it seems; key turns okay one way but not the other.
Old Jan 23, 2011 | 06:21 AM
MaD666MaX's Avatar
Rew rew rew your boat
mine works for everything, sometime i start my car and go away so i lock my doors with the small key since it wont work with the button on the handle. i can lock, unlock, start, trunk with it.
GARCIAC951
Sep 10, 2015 07:17 PM
TJSiegrist
Sep 10, 2015 09:29 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
