Heat
Old Jun 21, 2010 | 03:12 PM
Rote8's Avatar
Heat
I have found a cooler engine temp, when running A/C, by putting a spacer between the A/C mounting bracket and the radiator bottom bolt for the A/C mount. The A/C (condenser?) is then farther forward from the radiator.
Seems to work for me.
Anyone else have simple tips for a cooler engine?
Old Jun 21, 2010 | 05:38 PM
olddragger's Avatar
you mean the engine
bay?
OD
Old Jun 21, 2010 | 06:18 PM
Rote8's Avatar
Originally Posted by olddragger
you mean the engine
bay?
OD
1) Remove the car engine under-tray.
2) Remove the two bolts that hold the bottom of the A/C condenser to the radiator.
3) Get longer bolts and spacers, mine were 1.25 inches.
4) Spacers and longer bolts will increase the distance between the A/C condenser and the radiator.
5) Pettit cars will find the inter cooler sits more towards vertical.
cliffkemp
Dec 24, 2024 10:48 AM
05rx8mazda
Nov 28, 2015 09:42 AM
XianUnix
Sep 29, 2015 03:48 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Vedivan1
Sep 20, 2015 04:39 PM
