Strange a/c problem...
Old Jun 18, 2010 | 06:53 PM
BigMikeATL's Avatar
Starting yesterday I noticed my A/C, while on the coldest setting, occasionally alternates between very cold to mildly warm humid air.
Yes, I have done the diagnostic and everything is fine.
I have also noticed some visible cold air a couple times, though it's only for a few seconds each day.
It has been pretty hot the last couple days and I have been in stop-and-go traffic.
Anyone know what the problem might be? Does it just need a recharge or is there something else going bad?
Old Jun 18, 2010 | 07:30 PM
mushkid's Avatar
Smile,It confuses people!
our compressors are just weak!!!
do the ac mod to see if that helps (See Post #10)
https://www.rx8club.com/showthread.p...ight=colder+ac
Old Jun 19, 2010 | 11:57 AM
EDZRIDE's Avatar
2005 White GT
Could be lots of things; check the compressor belt tension and make sure the fans are working. If it's still not working, do the performance test according to the manual and post the readings.
Old Jun 21, 2010 | 05:06 AM
Jeff_Blair's Avatar
I'd keep the A/C reading up, and see if the numbers change(Hit power+Vol up). I know mine will go from 0 to about 5 if I hit a bump.. I need to fix that thing one day.
RevMeHarder
Jun 1, 2026 02:30 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
nadodave
Aug 28, 2019 05:55 AM
djp6783
Sep 19, 2015 12:12 PM
rxwilly8
Sep 2, 2015 02:42 PM
