P0302 cel need help
Old Jun 6, 2010 | 09:54 AM
Tex8's Avatar
P0302 cel need help
Yesterday while driving around town, the engine started wanting to die at idle and running really rough. started getting flashing cel, so i pulled over and noticed some white smoke coming from the back of the engine compartment(engine temp was normal). also noticed that the cat was extremely hot with very loud popping noises. so i had it towed back to the house and removed the cat figuring that it may have been clogged. But i am still getting cel codes P0302(rotor 2 misfires) and P0171(system running too lean). Should i replace the plugs next? any help is appreciated
ps: 04 6mt stock with 48000mi
Old Jun 6, 2010 | 09:59 AM
kingaaron's Avatar
When was the last time you changed your plugs and coils? They are only good for 25k-35k.
Old Jun 6, 2010 | 10:04 AM
Tex8's Avatar
to be honest i am not sure when the last time they have been changed. i bought it used about a year ago from a dealer and figure that they were changed before i purchased it but not 100%. i have only put 9 or 10k miles on it. does it sound like thats the problem?
Old Jun 6, 2010 | 10:12 AM
moonkid's Avatar
mine did the same last week i replaced the plug and im waiting for my wires n coils to arrive the cel turn off but in the mornings when i start it it still have some rough idle but hopefully will go with the wires and coil........ if u do it yourself remember to reset the e-shaft
Old Jun 6, 2010 | 10:35 AM
Tex8's Avatar
does anybody know if the cat is covered by mazda?
Old Jun 6, 2010 | 10:57 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yes, it's a federal mandate and the CAT is covered for 8 years or 80k miles.
Old Jun 6, 2010 | 11:21 AM
Tex8's Avatar
so when i get her running again can i just take it up to a dealer and have them replace it for FREE?
Old Jun 6, 2010 | 11:30 AM
Mazurfer's Avatar
If the CAT is really bad..............and it certainly appears that way, then the answer would be "yes".
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Sep 26, 2015 12:30 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
