Help
Old Jun 5, 2010 | 08:32 PM
usmckiller09's Avatar
Help
hello everyone i recently has a ap catback axhaust put on i was told the check engine light would not come on i got it put on last friday and yesterday the check engine light came on i took it to mazda and they said they wouldnt do anything cuz it would void my warranty. they hooked it up to a computer and they said a bunch of posibilltys came up the guy believed it was the o2 sensor does anyone have any ideas?
Old Jun 5, 2010 | 08:35 PM
nuke0907's Avatar
Never Blend In
if you installed it with the catless midpipe, you will get the CEL.
Old Jun 5, 2010 | 08:39 PM
help
is the catless the same as the cat delete pipe and if so would it come on a week later also it has been idoling a lil over 1 some time if its in neutrual it goes up and down sometime
Old Jun 5, 2010 | 08:41 PM
nuke0907's Avatar
Never Blend In
yes they are the same. you can get it to clear if you disconnect the negative terminal but it will come back in eventually. only way to make it go away permanently is to put your cat pipe back on.
Old Jun 5, 2010 | 08:44 PM
help
so the cat pipe from my original exhaust and whats up with the idoling problem
Old Jun 5, 2010 | 08:45 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
^................or mask it with the Cobb AP right?
Old Jun 5, 2010 | 08:56 PM
help
i have a 2010 cobb doesnt make one for my year
Old Jun 8, 2010 | 08:22 PM
04RX8man's Avatar
Rotary Powered Countryboy
no cat= cel.....try a spark plug defouler...or wait till an ap comes out
