Velocity_RXB
05-27-2010, 11:25 AM
Hi everyone, this below is copied over from my old thread on the UK owners club forum. Bits are cut out so sorry if it does not really flow. Just thought I would open it up to a wider audience and that it may help / inspire someone.
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8366.jpg
I marked some measurements on the panel made some cuts and scored a lip to form a hinged down flap. I wanted to have the cutaway positioned so that it would allow the monitor to be sat into it in such a way that allowed a good viewing angle but also kept the speaker grille in place and did not go too low down to prevent it from fitting backk into the car.
I then dismantled a all in one DVD monitor that was contained within a car headrest.
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8367.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8365.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8393.jpg
I then modified a plastic casing structure so the screen mounted flush against it and tried it for size in the hood panel.
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8364.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8396.jpg
Next I secured the casing in the right place with screws and began layering fibre glass over it.
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8407.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8408.jpg
Once I had built up enough layers to make it secure and start to give it some form I used P38 body filler to layer on top and further start to make a nice shaped surround.
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8411.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8412.jpg
After A LOT of sanding back it was time for a coat or two of high build and 2k primer folowed by a rough coat of random glossy paint just to show up imperfections better.
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8415.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8413.jpg
Then back to do a bit more low grit sanding before finally being ready to get a few top coats on. -
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8484.jpg
I did try some 'wrinkle finish' dashboard paint which would have been great if it was on a large flat surface but once it was on and dry due to the multiple angles on the surround it seemed to reflect light very differently on the vertical and horizontal surfaces and made it LOOK very patchy.Although if you where to look from a different angle you could see it was actually perfect all over. The photos don't really do it justice it was in fact a very intricate and even swirly pattern.
Any way I was not happy with the finish so had to spend blimin ages getting it all off again which was no easy task. Due to it being rubbery I had to literally scrape it all off with a knife. Sanding was no good as it simply got warm with the friction and made it go all gloppy and stick even harder! :evil:
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8462.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8464.jpg
When this was eventually removed it was back to the smoothing and prepping stage as the surface was left badly scarred and uneven.
It was at this stage I did consider the idea of trying to cover it in black leather.
However this was quickly dismissed as getting it to strech around the contours all in one piece was going to be near impossible. :(
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8432.jpg
Once it was nearly ready I went for a trial fit in yellow primer (which I think looks strangly nice and contrasting against the speaker grille, dash and monitor.)
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8416.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8425.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8422.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8420.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8419.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8423.jpg
When all was seen to be well I sprayed a top coat in a colour I was fairly happy with and then it was time to install the monitor, wire everything up and try it all out. 8)
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8579.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF8575.jpg
Repainted in a matt black to better match the dash and with a different design screen -
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF4707.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF4708.jpg
http://i466.photobucket.com/albums/rr21/Brockway84/Dash%20build/DSCF4701.jpg
Finished thing installed in a car.
You can wire it up to a free to air digital TV reciever, games console, reversing camera, CAMP 2 gauges etc and maybe GPS.
http://i385.photobucket.com/albums/oo294/Nigel425/DSC00194.jpg
http://i385.photobucket.com/albums/oo294/Nigel425/DSC00195.jpg
