How to Track When to Add Oil
Old Jan 30, 2004 | 03:56 PM
Hard 8's Avatar
Senior "Member"
I reset my "Trip B" mileage counter whenever I top off the engine oil.
Old Jan 30, 2004 | 04:10 PM
Genom's Avatar
Not so Super right now
Just check the dipstick every 500 miles or so and you should be set. Once you get the hang of how many miles between adding oil, you dont really have to worry about it at all. I know every 900 miles or so it's time to add 1/2 a quart.
Old Jan 30, 2004 | 04:17 PM
f1michel's Avatar
We need to relax about the oil thing. It burns a little oil yes but my rx-7 did take a quart every 1000 km (600 miles) and i loved that car to death.
Old Jan 30, 2004 | 04:51 PM
Hard 8's Avatar
Senior "Member"
Both good points. I'm just suggesting an easy way to keep track of the mileage between top-offs. Doing it every third tank or so works, too, but I submit that my way is a little easier and more precise, since it depends a bit less upon my lousy memory.
Old Jan 30, 2004 | 04:53 PM
310Guy's Avatar
4AT poor mileage king
What does the owner's manual say?
Old Jan 30, 2004 | 05:31 PM
Reeko's Avatar
It says to check the oil every time you fill up the gas.
At 200 miles a tank in my case, that's way too often.
After 5000 miles I have settled on checking/top off at every 1000 miles. I am ussually a 1/2 quart down at that point.
Old Jan 31, 2004 | 01:42 PM
Killerking1964's Avatar
Hmmmmm. All this talk about adding oil, and my 8 has not had to be topped off at all in 1,700 miles...............
Old Jan 31, 2004 | 04:25 PM
cruzdreamer's Avatar
Mine either.....finally had to around the 2200 mile mark. So, mine is not burning oil that badly! I check about every 800 miles or so just to be safe.
Old Jan 31, 2004 | 04:29 PM
mmmdowning's Avatar
I don't use it either, I wonder if the autos reqiure less oil consumption?
Old Feb 1, 2004 | 01:18 AM
bagman's Avatar
That must be it, because I'm at about 1200 miles and haven't had to top it off at all yet! (I've got an A/T)
Old Feb 1, 2004 | 04:50 AM
Outlaws eXtreme's Avatar
2010 Prius - Miss the 8
I've had to add about 3/4 so far of oil... I've got about 4000 miles in 2 months and 7 days of driving. Gosh dang, that's a lot of mileage I've put on the car.. ack, maybe buy a second one ready...
Old Feb 1, 2004 | 05:08 PM
Genom's Avatar
I will admit to driving the car.. spiritedly :D
Seriously though, I put in a little oil every 2000 miles and havent had problems with that. Just hit 10K this morning.
BTW, drove to the keys for the weekend and got a pretty decent 24.2 MPG while running the AC the entire drive. Was raining the whole drive down and back up, but weather was good enough while we where there.
Old Feb 2, 2004 | 09:51 AM
Draig's Avatar
It seems that the oil drinking aint quite as bad as people think. Its more to do with the fact that if you let your piston engine run VERY low then you will normally get away with it. On a rotary you probably wont get away with it. So they put so much fear in you that you never go too low.
BTW, Mazda technical reckon that after about 5-6K miles you should find that the oil consumption goes down so it wont need to be topped up so often.
Mike
Old Feb 2, 2004 | 10:36 AM
o_town_racer's Avatar
From what I've read, you use more oil the more "spirited" you drive. Therefore, easy on the gas pedal = lower oil consumption.
Old Feb 2, 2004 | 10:43 AM
Draig's Avatar
True ... but I like to drive my 8 like its meant to be and its still pretty good for oil. (I am only getting 12-14MPG of fuel out of it as I have a heavy right foot)
Mine is a UK Hi-Power model so whether the tuning differences over this side of the atlantic makes a difference, I dont know.
Old Feb 2, 2004 | 11:14 AM
MMGDC's Avatar
Oil costs what, $2 a quart? It's insane worrying about excess oil burn during spirited driving.
I found myself about a quart down after 2000 miles. Going forward I figure I'll need to throw in an extra quart midway between oil changes and I'll be fine.
Old Feb 2, 2004 | 11:33 AM
BlueThunder's Avatar
You should check the oil every 1000 miles regardles of what kind of car you driving. Why? Because you never know what could happen during your driving. This way your always safe. After a while becomes a habit. I would hate to see any car burn out because of low oil, and especially my RX8!
Old Feb 5, 2004 | 09:48 PM
RX8driver's Avatar
My oil light came on at only 1000 miles after my last oil change. I was down easily a quart.
I will be watching it much more closely now.
Jesus Martinez
44
May 6, 2025 08:09 AM
jay_tibo
22
Sep 13, 2016 08:10 PM
