Series I Do It Yourself Forum Wanna save some coin or time/money in the shop? Read up on Do-It-Yourself custom mods and repairs & post your own here.
DIY: Throttle Body & Upper Manifold Removal (retitled)
Old Apr 29, 2010 | 04:45 PM
big rooster's Avatar
I need to check my throttle body and upper lower manifold and if need be clean them due to a oil problem i have.
Any one no if there's a detailed thread on how to do this task as i wont to stop any future problems .
Thanks for any help given.
Old Apr 29, 2010 | 05:33 PM
Jon316G's Avatar
Grasshopper
No detailed DIY that I know of, but I can try to describe the best I can...
Throttle Body:
1) Disconnect the electrical connection to the TB.
2) Remove the four long bolts on the front of the TB.
3) Leave the coolant hoses attached and swing the TB out of the way.
UIM (Upper Intake Manifold)... going off of memory:
1) Remove electrical connection to purge solenoid (front-centered on UIM... to the right of the oil filler neck).
2) Underneath the purge solenoid you'll see a line with a blue disconnect, remove that.
3) Standing on the drive's side of the car, right behind where the TB was mounted, is a fitting for the VFAD.
...3a) If you still have a VFAD, remove hose.
...3b) If you don't have a VFAD, ignore because it should be capped
4) Like how the VFAD fitting is position underneath, run your hand under the UIM and around the first bend, you'll feel another hose that is used for a vacuum chamber for the AIR, SSV, and VDI solenoids. Remove that hose.
5) On top of the UIM is a thicker hose for the brake booster. Loosen clamp with pliers and move it away from fitting. Disconnect hose.
6) Look between and below UIM and brake booster... you'll see two lines, one with a red clip and the other with a blue clip (blue clip line is the other end of what you disconnected earlier). You'll see they are attached to a 90 degree bracket with "zip ties". Separate the lines from the bracket (DO NOT disconnect lines, just separate them from the bracket).
7) Here is a tricky part... behind the bracket are two bolts that attaches the oil neck to the bottom of the UIM. Easiest way to get to these bolts is to take pliers and bend the bracket up (basically straightening it). Then the bolts will be visible and easier to reach. Remove the two bolts.
8) At the other end of the UIM where it connects to the LIM, remove the three bolts. The one against the firewall is the trickiest. A ratcheting wrench helps, but I've got a good combination that works consisting of a socket -> short extension -> u-joint -> long extension -> socket wrench. Experiment with what you got.
9) Once the three bolts are removed, look towards the center of the UIM and you'll see two bolts, one on each side, connecting the UIM to the auxiliary runners.
Remove the two bolts. (the one against the firewall is tricky too, but easier).
...NOTE: No need to remove the bolts securing the auxiliary runners to the LIM yet... wait until the UIM is removed for easier access.
10) Once you get those two bolts out, remove the oil fill cap and lift the UIM out (then put the oil cap back on).
11) Now you can remove the four bolts (two on each side) that attaches the auxiliary runners to the LIM.
12) You're done... so grab a beer!
Next time I have mine off I'll try to remember to take pics for a proper DIY.
LIM (Lower Intake Manifold)... Don't bother. Too much work and requires removing the engine. Its been done without removing the engine, but it was VERY tricky.
Only "oil in intake" issues with the LIM is the SSV, but there is a separate DIY for removing and cleaning just that valve so the whole LIM doesn't need to be removed.
Old Apr 30, 2010 | 03:23 AM
Jon... All i can say m8... hell of a good write up must have taken you some time ... big thumbs up thank's million.
Old Nov 22, 2010 | 07:39 AM
wcs's Avatar
wcs
no agenda
Thanks Jon
I'm going out to do this today.
I need to get access to the fuel line underneath the UIM.
Old Nov 23, 2010 | 02:25 PM
wcs's Avatar
wcs
no agenda
Hey Jon,
I know you did this from memory .... just thought I would add some to it for posterity
I'm working on a 05 MT
Note about section 1: I think if you are stock you don't have to necessary unplug MAF electrical connection but its nice to get out of the way.
Throttle Body:
1A) Remove the hose clamps around the rubber according tube
1B) Remove rubber tube
neck).
Note about 2: These connectors can be tricky and always feel like they are going to break to me. To remove these connectors push blue clip on the one side back until you feel it click. Connector should now be free to disconnect.
VFAD.
hose.
I coudn't find the Air, SSV, VDI air as discribe above, or at least it doesn't seem to be in the same location.
The way it seem to be setup on mine 05 was 3 seperate vacuum hoses along with an electrical connector for each the Air, SSV and VDI solenoids. I found it easier to remove these after the UIM was free and I could get my arm down in there.
I was able to reach mine without having to do this, a long 12" extension works nicely.
back on).
Top of UIM
Tricky bolts
I choose this time to remove the Air, SSV, and VDI vacuum hoses and connectors. The connectors have a little tab on the top toward the passenger side. Pull and hold the tab in then disconnect.
The Reach Around
Connector terminals at the rear
Vacuum hose connectors - picture from front, with one hose removed already
I grabbed two beers because I have a problem ....
Old Nov 23, 2010 | 02:39 PM
DarkBrew's Avatar
Extraordinary Engineering
Cool!
Nice pictures!
Wish I was there!
Wish I was drinking your beer!!!
Old Nov 23, 2010 | 02:58 PM
wcs's Avatar
wcs
no agenda
LOL
I couldn't believe how easy it was .... Only took about 2ish hours to tear down and put back together.
Hardest parts where trying to unplug those solenoid connectors and not damaging that darn oil pressure tube.
LOL thinking about it .... I only ever used the 10mm socket! How awesome is that?!
Old Nov 23, 2010 | 03:12 PM
wcs's Avatar
wcs
no agenda
Originally Posted by DarkBrew
Cool!
Wish I was there!
Oh and I've saved plenty of heavy lifting for you .....
I just wanted the car not to catch on fire before than
Old Dec 26, 2010 | 10:32 PM
stinksause's Avatar
The Stink w.o The Sause
I still can't do it ... those two bolts are the only thing holding me back
Old Dec 26, 2010 | 10:35 PM
TX
What two bolts? I just replaced my oil injectors and OMP lines and all I can say is, "liquid wrench" the bolts. I broke one of these and it turned a day long project into a couple of day project.
Old Dec 26, 2010 | 10:48 PM
stinksause's Avatar
These two .... PaIn in My ******** ....
I've been trying different organizations of extensions and joints and I still can't do it ...
Old Dec 26, 2010 | 10:59 PM
RX8Soldier's Avatar
Time for boost...
sorry to jump in, but this is excellent info!! Someone want to turn this into a DIY and post there?
Again, awesome stuff!
Old Dec 26, 2010 | 11:13 PM
stinksause's Avatar
It kinda already is a DIY ... its just not called as such ...
Old Dec 26, 2010 | 11:21 PM
RX8Soldier's Avatar
Time for boost...
just thought for searching purposes it would be easier to find in the DYI. I've already bookmarked this as a DIY
Old Dec 26, 2010 | 11:59 PM
picture worth a thousand words ...
if you're still confuse, dig that shop manual out and look at it
Old Dec 27, 2010 | 07:26 AM
wcs's Avatar
wcs
no agenda
I used a 3/8 drive 10mm deep socket, then a universal joint (swivel) connected to a couple long extensions ... about a foot long in the end.
Those suckers where in there tight ... real tight ... I think they actually did have loctight on them.
Just make sure the socket fits snugly before you lean in to it ... rounding the head on those nuts would be a bitch.
Old Dec 27, 2010 | 07:32 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
You have more than one?
Old Dec 27, 2010 | 11:22 AM
stinksause's Avatar
http://msnbcmedia2.msn.com/j/msnbc/C...p.grid-6x2.jpg
This guy does ...
Old Jun 18, 2011 | 07:10 AM
NYC Drift King's Avatar
Supercharged by Pettit
Old Dec 19, 2011 | 10:31 AM
r-enzyme's Avatar
For the Masses
Jon, your help has been monumental in assisting me remove & clean the APV barrels, the SSV and the VDI valve.
Do you recommend trying to clean the interior channels (there may be a better phrase here) of the LIM? Is there an effective way to do this?
Old May 24, 2013 | 09:32 AM
RA12726's Avatar
Thanks alot for this thread. It's been very usefull.
For other readers, here is one more threads on this forum that I've also found usefull.
https://www.rx8club.com/series-i-tec...-244654/page2/
Also for information: I've found that the two bolts on the upper intake manifold (next to throttle body) that hold a bracket for two cables, are easier to remove if you jack the car and use a long extention from underneath the car.
Now that I've had the experience of having it done once. Let me know if you need any help. Who know, I might be able to give good advise.
Oh and the two nasty botls near the firewall. Use a universal joint. Much easier.
Old Jun 7, 2013 | 02:24 PM
GK1707's Avatar
Does anyone have a diagram or pic of how the three vacuum hoses behind the UIM go back. I put mine back and think I may have mixed up 2 hoses. Cars running fine but I have a CEL for the air pump and when shutting the car off, I hear a "Brrrrr" noise sounding like the air pump.
Old Jun 7, 2013 | 03:14 PM
Google RX-8 Vacuum Hose Diagram.
Old Aug 6, 2013 | 05:18 PM
ottocycle's Avatar
Awesome DIY!
I would add two things.
1.) Before you can lift the UIM out of the engine bay, you'll have to unclip the small wiring harness from the front-middle part of it.
2.) Before reinstalling the UIM, take the dipstick out. It's very easy to get the UIM caught on the dipstick loop and bend it.
Old Aug 6, 2013 | 05:23 PM
paimon.soror's Avatar
I'll eventually make a DIY in the S2 section, but if someone needs a more picturesque diy: Normalexception.net - 2009 - 2011 RX8 UIM Removal
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
