greddy turbo kit in rx8 an wont start need suggestions
Old Apr 20, 2010 | 08:49 PM
Less Than Fi<e's Avatar
Angry greddy turbo kit in rx8 an wont start need suggestions
just installed a greddy turbo kit for my 04 rx8 an its cranking but it wont start. i do not have the medal plate in the manifold like it said? an i have a breather filter on my oil top where the cap is..is this the cause of the problem i need help i dont no what the problem is
Old Apr 20, 2010 | 08:51 PM
gregs's Avatar
Pull My Finger
what engine management are you using? did you install the kit yourself?
Old Apr 20, 2010 | 08:53 PM
MazdaManiac's Avatar
More details.
Old Apr 20, 2010 | 08:55 PM
engine management is "E management" all bolt on greddy kit did it myself. turbo is t618z...i guess
Old Apr 20, 2010 | 09:02 PM
Brettus's Avatar
Boosted Kiwi
It could be flooded - try push or pull starting it .
also try disconnecting the Emangle & reconnecting the stock ECU (just to get it going)
Old Apr 20, 2010 | 09:04 PM
also, where is the jet air fuel mixing hose?is it very important for the car to run? im not sure if i did this part correctly, the kit did come with a BOV which im pretty sure is done right, im going to try these suggestions right now also
Old Apr 20, 2010 | 09:14 PM
Brettus's Avatar
Boosted Kiwi
Probably a good thing you can't get it started because it sounds like you need to do some reading up before you go much further .
First thing to do is order the Accessport from MM (the guy in post 3) - the Emangle is a poor tuning option and will give you more headaches than you can imagine right now .
Then while you wait for that , read up as many turbo install threads as you can starting with the 'greddy turbo fixes' thread .
Once you get the car started you can run it NA (up to about 5000rpm ) on the stock computer , if you pull off the wastgate control arm .
Old Apr 20, 2010 | 09:57 PM
do u think its flooded? if so how do i unflood it
Old Apr 20, 2010 | 10:00 PM
Brettus's Avatar
Boosted Kiwi
There is a deflood proceedure in the owners manual .
But way better to push start it - do you know how to do that ?
Old Apr 20, 2010 | 10:03 PM
imma post pic of my set up
Old Apr 20, 2010 | 10:07 PM
ya i no how to push start it....but even if its cranking it could still be flooded you think?
Old Apr 20, 2010 | 11:36 PM
The greddy turbo kit comes with a medal seal plate that goes I'm the
intake manifold to block a hole. Well I
never put that in. Would that have somthing to do with it. An if I shorten up the vacuum lines will that help vacuum pressure to help it start
Old Apr 20, 2010 | 11:42 PM
Brettus's Avatar
Boosted Kiwi
very possible .
Old Apr 20, 2010 | 11:44 PM
Brettus's Avatar
Boosted Kiwi
none of those will stop it from starting .
The blocking plate is a good idea but not essential .
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
SUKIEE
Oct 9, 2017 09:41 PM
robd1337
Jul 31, 2015 09:35 PM
AussieGray
Jul 16, 2015 03:58 AM
