LIttle of topic (HELP)
Old Apr 14, 2010 | 02:06 AM
alex zhuk's Avatar
Hello, so my girlfriend has a 92 camry and it runs great, or did. today i had found some extra engeine degrease and decided to clean her bay up a little since it looked like it hadent been touched for a while. i let it set and then washed it down with water as i always have done on my winter beater(94 max) then when we went to start it it wouldnt crank. so i took the spark plugs out and they were wet. i let them sit all day, when i came home at night i throw them back in and the car started. i let it sit and warm up, then started to drive around the block, then out of no where it started bogging out and then died. i waited a min and started it back up, i then went to the gas station(putting along) and throw some gas treatment in it and a some gas, on the way home i noticed that when you floor the gas it starts to bog out and acts like a very rough idle. if you slowly push the gas it runs fine. also when its idle in park it has a rougher idle then it used to....?
what could this be?
fuel injectors
egr valve
or did the plugs get damaged completely?(thought this didnt happen with a lil bit of water)
she needs her car tomorrow for work so i need to figure out the problom
thanks
Old Apr 14, 2010 | 08:59 AM
Grungepup's Avatar
Oilfield trash
check for a wet air filter
a hole in the intake piping
Jesus Martinez
72
Jul 26, 2023 11:29 PM
UHATEIT
Mar 31, 2019 05:31 PM
Dokuji
Nov 1, 2016 02:51 PM
rx8girly
Sep 22, 2015 03:50 PM
groll69
MW RX-8 Forum
Aug 17, 2015 04:21 PM
