IAT sensor
Old Apr 12, 2010 | 05:42 PM
Rx8 07's Avatar
IAT sensor
First of all im a newby, so today i went to have someone look at my car because it doesnt some annoying noises, after we got done with that, he told me that i should get a resistor or recesstor, from radio shack for $2,get the one resistance at 68'C, and my check engine light will go off(i thought it was because the catback has more compacity), the car will run better and i can save more gas. im really confuse about this crap and i want to know if its worth the try.
Old Apr 12, 2010 | 06:54 PM
Old Rotor's Avatar
Please give us the history on your car, year MT/AT,miles etc just anything you can add... The service it's had parts replaced. When do you have your "annoying noises".
Old Apr 14, 2010 | 05:42 PM
Rx8 07's Avatar
Sry i didnt make it clear, its not the noise that i'm asking. the noise problem already solved, was cost by the heat shield and exhaust banging each other.
but the sensor, the two guys suggest me to put on a resistor, where my CIA connect with the car, i think one is called "MF" another is vacuum not sure, but the one has less core was not connected with the intake because i cant find anywhere to plug it in >.<. if i can remember right it was 3 wires tie together.
Old Apr 14, 2010 | 05:50 PM
Brettus's Avatar
Boosted Kiwi
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOooooooooooooo !
Old Apr 14, 2010 | 05:55 PM
expo1's Avatar
He's as bad as Can
No it's not worth the try and do not seek any more advice from those people. If all it took was a cheap resistor to make the car run better and improve fuel economy way didn't Mazda put one on it?
Old Apr 14, 2010 | 06:25 PM
Rx8 07's Avatar
OK thanks guys. But what do i do with it tho? i mean is the plug just suppose to hanging there? dont have to connect with anywhere? Does everyone that have CIA all have their CE light on?
Old Apr 14, 2010 | 07:04 PM
lilring's Avatar
Finally a MT
take a picture of what your talking about so we can understand what your talking about.
Old Apr 14, 2010 | 07:41 PM
Rx8 07's Avatar
k im going to do that right now
Old Apr 14, 2010 | 07:52 PM
Rx8 07's Avatar
Just this thing,dunno where to connect. It has two wire, they are orange and blue.
https://www.rx8club.com/attachment.p...1&d=1271292705
Old Apr 14, 2010 | 08:05 PM
Rx8 07's Avatar
Originally Posted by GeorgiaBII
That is for the Vfad that you no longer have. Just tie it out of the way and relax. Your CEL is on for another reason.
ok sweet so i can just cut it off?
My friend read the code for the CE before he told me that "its cause by the catback i put on because it changed the capacity ," so in another word that everyone did upgrade midpipe or catback will have the CEL on?
Old Apr 14, 2010 | 09:09 PM
lilring's Avatar
Finally a MT
if you put a midpipe on.. most likely you will have a CEL unless you mask it with a Cobb
Old Apr 14, 2010 | 09:47 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yeah, don't cut it..............just tie it back out of the way.
And..............as someone already said..............if you did put on a midpipe along with the exhaust, then you will get a CEL. Did you see when they installed the exhaust? How far up towards the engine did they replace? Oh.....and don't listen to whomever these two guys are, or you aren't hearing clearly at all.
Old Apr 15, 2010 | 04:30 PM
Rx8 07's Avatar
Ok i got it, thanks so much guys. im saving up for a Cobb, so its perfect.
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
Evan Gray
Nov 24, 2015 01:00 AM
XianUnix
Sep 29, 2015 03:48 PM
