Review: GTSPEC Upgrades
Old Apr 11, 2010 | 08:32 PM
L337fpc's Avatar
ლ(ಠ益ಠლ)
Well I have installed the GTSPEC 6-point front strut tower brace (awesome), Rear Lower Tie Brace, and Rear Lower Lateral Tie Brace. In addition I have installed Progress sways, Megan Racing Camber Kit, and Tanable Pro OC-S coilovers. This is all for
Now to the nitty gritty. I have to say I ran on Englishtown's Open Track last year and I thought my handling couldn't get any better...WRONG. The sways and 6-point front strut brace make the car rock solid for aggressive driving. The rear tie bracing has locked the rear and has eliminated a bit of wheel hop when launching.
All of these suspension mods have boosted my confidence in my car by a good amount.
NJMP Time Attack
I participated in the Test and Tune sessions at New Jersey Motorsports Park's Lighting course on Saturday. I was passing modded Evo's in my class (RWD) like it was a breeze. I am no pro driver by any means. But these mods and a SS Clutch Line...the car is completely smooth in power and grace in and out of turns.
Installation Notes
6-Point Front Strut Brace - Install the chassis pieces first, LOOSELY! Then loosely install the other pieces. That will save you lots of time and aggrivation.
Rear Lower Tie Bracing - You will most likely need an alignment after installing it (unless you can perfectly wrench the alignment lobs). These bars are very very tight fitting; and trust me its worth it.
Pics!
6 Point Strut Brace
Lower Rear Bracing
Tanabe Sustec Pro OC-S (full drop 2.5in)
I highly recommend the GTSPEC bracing. Next up on my list of bracing is the 6 Point Rear Strut Brace.
EDIT 6/11/10
I finally installed the Front Lower Tie bracing...and omg awesome. I attached pics of how the installation pieces are supposed to be setup. It took me 3 attempts to figure it all out. You need air tools install the 2 mounts in front of the oil pan.
Attached Thumbnails Review: GTSPEC Upgrades-imag0387.jpg   Review: GTSPEC Upgrades-imag0388.jpg   Review: GTSPEC Upgrades-imag0390.jpg
Old Apr 12, 2010 | 02:26 AM
volcomx31's Avatar
Silver Power
nice!
Old Apr 12, 2010 | 02:28 AM
Gr8Bullet's Avatar
Im Sir Earl of Sandwich!
Pretty sweet just watchout for speedbumps lol
Old Apr 12, 2010 | 06:58 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
You know its really not bad at all. I normally took speed bumps from side to side any way. The one thing is that the Rear Lateral Tie Brace does sit ~.5in lower than any other part on the car.
Its nothing of concern, unless your sitting really low in a very bumpy area. But those GTSPEC bars are crazy solid; they can take the abuse.
Old Apr 17, 2010 | 02:06 PM
-RX8-'s Avatar
So you installed all that at the same time? Or just the bracing?
Old Apr 18, 2010 | 06:23 PM
L337fpc's Avatar
ლ(ಠ益ಠლ)
All within a one month period.
Old Jun 11, 2010 | 06:55 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
Bump!
Installed the Front lower tie bracing and updated first post.
When installing the Front lower tie bracing, you need air tools. The trick is to keep at it until your impact gun can't spin the top nut for at least 30 seconds. By that time the mounting piece has expanded and it solid in the mounting hole.
Even though it was a royal PIA to install...it was so f'ing worth it. I just wish i had installed this before the track.
Old Jun 11, 2010 | 07:42 AM
mscamp02's Avatar
Blue Bullet?
nice they look pretty good and mesh well with a wb.
Old Jun 11, 2010 | 10:15 AM
Race Roots's Avatar
Former Sponsor
Glad you finally got it squared away, that underbody 6 point blows my mind on the improvement.
Enjoy it!
Old Jun 12, 2010 | 09:44 PM
HiFlite999's Avatar
Originally Posted by L337fpc
Bump!
?? I did mine w/o air tools, using their little installation tool. It works just like an aircraft riv-nut: screw the threaded rod into the expanding nut from the bottom, slide the hex-piece over it, hold it in place, put one wrench on the hex to keep it from spinning, then draw down the stud with a washer and hex-nut and a second wrench. Kindof awkward, but def can be done without air.
Old Jun 13, 2010 | 10:08 PM
fd3s777's Avatar
www.EVO-R.Net
I have these on my 8 loving it. Specially on track!
Old Jun 14, 2010 | 03:34 PM
elysium19's Avatar
random question - what sort of lap times were you pulling at NJ motorsports park?? (lightning course)
And what tires were you running?
Old Jun 14, 2010 | 03:49 PM
L337fpc's Avatar
ლ(ಠ益ಠლ)
1'27"xxx's were my consistant best times w/o traffic on the course. I ran with low compression on my front rotor (~93psi) and OE pads n rotors. Yokohama S.Drives.
Old Jun 16, 2010 | 11:49 PM
elysium19's Avatar
Cool.....was just curious. I'm trying to see how fast a N/A rx8 can go on that circuit. I was running just shocks/springs but damn good road tires (bridgestone potenza's) and I pulled some 1:22's. My engine was healthy tho ;-) I'm pretty sure the tires are a far more significant player than bracing or really anything else for that matter....you like the Yokohamas? I think chassis stiffening is cool but it seems way down the list for mods, to me at least. I hate to say it, but with a car with 190whp.....how much do they weigh?
http://www.youtube.com/watch?v=QrRIVVAsL8w&hd=1
It's a really fun track, at the end of the long straight, the rx8's brakes really shine, I was going wayyyyy deeper than really anyone else there.
Have fun....
Old Jun 17, 2010 | 05:15 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
Yea low compression really f'ed with me in the straights. The S.Drives are nice...but not fully track worthy. Also, i need better brakes. By the 2nd 30min session...yea...those pads were roasting.
I weighed in at 2765lbs with my Greddy SP2...ive got the HKS hi-power now.
Old Jun 17, 2010 | 02:04 PM
elysium19's Avatar
You got the car down to 2765 pounds?????? Howd you pull that off??? The progress bars alone weigh a billion pounds!
Old Jun 17, 2010 | 03:34 PM
L337fpc's Avatar
ლ(ಠ益ಠლ)
I have no idea. Thats what Red Line's scales said. The s.drive's are 24lbs a tire...mazdaspeed flywheel...no spare...no carpet...um. look @ my vgarage, i listed it all there. Link in my sig.
Old Jun 17, 2010 | 03:42 PM
WTBRotary!'s Avatar
Drummond Built
I believe the 3,000 lb is the weight of the GT, so add more for leather and sunroof etc. The base and sport models way less...
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Quiggs321
Sep 30, 2015 05:34 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
drlubell
Sep 26, 2015 11:58 PM
