No POWER at High Speed then Stalls when I stop at light
Old Apr 6, 2010 | 10:18 PM
Jewbin's Avatar
Unhappy No POWER at High Speed then Stalls when I stop at light
OK... I have read so much i Think I have Hurt myself... LOL
2004 RX8 Manual. 82k.
On Highway runs at good speed when going uphill I lose power..I press the pedal and nothing...Then when at the crest of hill it starts to pick up speed...Sometimes even on flat road same thing...Then I get off highway and come to light and BAM the car stalls and won't start I have to wait like 15 mins and then it will start. (if i catch it and feather the pedal it evens outs and will idle)
Sometimes it sputters while trying to push the pedal... going up hill on highway runs speed is anywhere from 60 -90 mph
I have noticed the warmer its getting out the worse it gets. Now the 8 does it in 3rd gear around town it feels sluggish like its restricted...If you understand what I mean.
I had 2 CEL it was Rear bank O2 sensor replaced and it was engine misfire.. I cleared codes at a Advance Auto about a week after the O2 sensor was replaced...(O2 was replaced by Mazda Dealer it was in there for something else and they took care of it because it was up on list already.)
I have replaced the Coil and Plugs about 5k ago I have cleaned the Fuel Sock in Pump. Replaced Air Filter.
PLEASE HELP ME.......
Thanks in Advance
Old Apr 6, 2010 | 10:24 PM
dozer's Avatar
on his 3rd rx8
you replaced ALL 4 coils and ALL 4 plugs? are they on tight?
Old Apr 6, 2010 | 10:27 PM
Jewbin's Avatar
Yes...... after I replaced Coil and Plugs No Problems.
dozer's Avatar
on his 3rd rx8
engine misfires have nothing to do with the 02 sensor, misfires are causes by bad spark plugs and/or ignition coils, what other CEL codes did you pull up?
Old Apr 6, 2010 | 10:28 PM
dozer's Avatar
on his 3rd rx8
and you still have a loss of power?
Old Apr 6, 2010 | 10:33 PM
Jewbin's Avatar
I had a rear bank CEL so I replaced the O2. I replaced the Coil and plugs about 5K miles ago and this is a recent thing in the last 1000 miles. When i replaced the Coils and Plugs it was Maint..... NOt any kind of Problems.
Another bit of Info.... It idles really jumpy lately.
Thanks bro.
Old Apr 6, 2010 | 10:44 PM
dozer's Avatar
on his 3rd rx8
take it out for a hard drive, then look under the car and see if the catalytic converter is glowing, if it is then ur cat is GONE...i cant think of anything else why ur car is acting up, its either that or ur engine is done
Old Apr 6, 2010 | 10:56 PM
Jewbin's Avatar
HA HA HA HA Thanks for that..."Engine is Done" Will The CAT actually GLOW?...I have been thinking it was the cat... I drive the car Nice not to hard... She is my baby LOL
heyarnold69's Avatar
Rotary wanabee
clogged cat?
Old Apr 6, 2010 | 10:58 PM
Jewbin's Avatar
Unhappy LOSS of Power at Highway Speed Going Up hill
Thanks in Advance
Old Apr 6, 2010 | 11:10 PM
Jewbin's Avatar
How do I check if Cat is Clogged...And I have thought it was all along.
Old Apr 6, 2010 | 11:32 PM
Old Rotor's Avatar
Search loss of power..here is a"TSB"...
http://www.finishlineperformance.com...4-08-1924g.pdf
Old Apr 6, 2010 | 11:47 PM
tubingchamp's Avatar
What mawd bug?
It will glow red hot after a hard drive.
Drive your car hard, and your cat shouldn't clog as easily.
Old Apr 7, 2010 | 12:00 AM
tza0001's Avatar
Dum Spiro Spero
What about your plug wires? Have you ever replaced them? The wires fail like spark plugs and coils (they have a longer life than spark plugs and coils but they go bad as well at some point). Further, you might want to check if the wires are tight.
When you say you don't drive it hard, what exactly do you mean? You need to redline the engine frequently (some suggest once a day) to burn the carbon.
Old Apr 7, 2010 | 12:50 AM
alnielsen's Avatar
I had the same problem. It's the fuel pump. It's getting hot. To confirm this, when your having the problem, put fresh gas in the tank to cool the pump off. If the problem goes away, it's the pump.
Do the test before you start throwing parts at the car and waisting your money.
To repair you have two options. Get a OEM pump assembly to replace yours and either you or the dealer replaces it (special removal tool required). The other is, if your handy, is to get a Black Halo Racing pump that goes into your present pump assembly (again special removal tool required). There is a DIY, by MazdaManiac, on how to perform the swap. This is the route I took.
Old Apr 7, 2010 | 04:08 AM
bse50's Avatar
#50
Get your compression checked\Inspect the catalyzer\replace the fuel pump.
Those are the most common causes.
Old Apr 7, 2010 | 08:28 AM
alnielsen's Avatar
2 threads were created by the OP that were the same. These were merged.
Old Apr 7, 2010 | 09:15 AM
otakurx's Avatar
Rotorheaded Geek
I'd also say fuel pump. Sounds very similar to when my pump went in my old RX-7 and now I'm seeing some of these same things as noted below.
On cold mornings I have a very rough start, rough as in no fuel for the first 5-8seconds. I've done a couple preliminaries to check this from watching the OBD2 read outs to doing de-flood and noticing no change between the sound/speed of the cranking with the pedal fully depressed or otherwise. Then the car starts up sputtering for a moment before idling smooth at 800 to 820RPMs. Then I've noticed that when it gets above 70*F in the mid-day sun now she will begin to not be able to keep up with the airflow (watched MAF readings and compared to lambda readings) so I get fuel starve when I reach a certain flow amount.
That being said, I was wicked paranoid at first about having a blown motor till I started reading all the fuel pump threads, esp since I'm up around 150k on the original engine.
Anyway, for those who get to this line, thanks for reading my medium winded post and I'll stop here since I'm not about to thread jack.
=P
Old Apr 7, 2010 | 09:47 AM
Jewbin's Avatar
Thanks to ALL... I am thinking Drive it hard and look at CAT (probably best to do this at night to see it Glow easier)
I do Redline Car about once a day.... When cold The 8 Drives great good pedal response and quick like it should be. as it heats up and the weather is hot out UGHHHHHH a pig she is LOL ...
So I will look at Cat Tonight.. If it is the CAT can I just remove the insides? I live in a non emission state so no tests.
Probably need to change Wires any way..When I changed Coils and plugs they looked NEW I purchased the car with 43k on it.
Thanks again
I can do a fuel pump swap no problem I have already been in there once to clean the fuel sock NO SPECIAL TOOL REQUIRED... Small Hammer and a Big Screwdriver and Patience...LOL
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ladnarf1
Apr 29, 2021 11:53 PM
Nisaja
Aug 6, 2015 01:27 AM
AussieGray
Jul 16, 2015 03:58 AM
