2009 R3 Bluetooth...help?
Old Apr 5, 2010 | 11:03 PM
Amalinze's Avatar
So I've got my sweet new car, and I have only one complaint so far. When I use the built-in bluetooth to talk on the phone, the sound is really faint, and only comes from the right-passenger door speaker. No problem, I thought, I'll just crank the volume to a reasonable level (typically in the 50's). So then I'm driving down the road, and the car begins to speak to me: HOLY **** YOU'RE GETTING A CALL! AAAAAAHHHHHHHH.
Suffice it to say that with the volume up at 50-something for the bluetooth, the voice of the car is ear-shatteringly loud. But calls sound fine. Is there some way to make the incoming call use the whole system instead of 1 speaker so I don't have to crank it up? There don't appear to be any balance controls for the bluetooth, and I don't think having centerpoint on/off makes any difference.
It seems like the sort of problem someone would have noticed the first time they tried it and then redesigned it, unless I'm missing some sort of really obvious setting somewhere.
Suggestions?
Old Apr 8, 2010 | 10:41 AM
Chibana's Avatar
The Michigan "WANKEL"
Strange. I don't have a problem with that and my BlackBerry Tour and my 2009 GT. I'm not sure what to recommend, other than perhaps checking with the dealer.
Old Apr 8, 2010 | 12:41 PM
jasonrxeight's Avatar
its all four speakers in my car.
Old Apr 8, 2010 | 07:08 PM
fyrstormer's Avatar
2009 RX-8 Touring
It sounds to me like the volume on your phone is turned down too low.
Old Apr 8, 2010 | 10:58 PM
CelticFan's Avatar
Could it be the phone? Mazda has a list of all the phones that work and the ones that don't on their site. It says that some work "with problems." I used the list to buy my last phone to make sure it work.
http://www.mazdausa.com/MusaWeb/disp...rior/bluetooth
Old Sep 27, 2012 | 07:04 AM
kash786's Avatar
hi guys, i have a mazda rx8 r3 2009, my bluetooth was working fine until few weeks ago, when i tried to connect my phone with the car, the lady spoke" PLEASE SAY YOUR FOUR DIGIT PASSWORD" i never had to use the password before to connect my bluetooth, i tried 0000 i also tried a few that i could think of but it keeps saying "INCORRECT PASSWORD AND COULD NOT CONNECT" im using a HTC EVO 3D phone, my bluetooth system has been fine since i bought the car but now it wants a password which i dont remember. in my phone wireless setting it says "mazda paired but not connected" when i try to connect my bluetooth it requires 4 digit password. please help
kash
Old Sep 27, 2012 | 07:24 AM
no you say the password to the car then you enter the password on your phone to pair. please read the manual again.
Old Sep 27, 2012 | 07:31 AM
paimon.soror's Avatar
also make sure when using an android phone that you follow the prompts on the phone. It will ask you if you want to allow the vehicle to look at your contacts. Select yes or else it will not connect.
Old Sep 28, 2012 | 10:46 AM
kash786's Avatar
it wont give me an option to type it on my phone. it says" please say the four digit code" and as soon as i say the 4 digit code it says "pairing failed" i have to press "paired but not connected" option on my mobile to connect my bluetooth system but it requires the 4 digit code which i can not remember. i never had this problem before, remember it has been fine for over a year, it has been connected and it always worked fine until one day it decided to require a 4 digit code. i still have all my contact names and numbers saved in my cars phone book but i cant connect my bluetooth anymore.
Old Oct 3, 2012 | 04:53 PM
Chuckdumper's Avatar
built in bluetooth usually never works properly...the only car i've had that it actually worked well in was my wifes camary and from what i understand thats not common...but with that said my x5 has built in bt and i have never even used it. I came across this Jabra Cruiser 2 speaker phone and have never looked back...it connects easily when i get in the car, a simple touch makes the connection and its all butter from there. When i want to hear music/gps...really any multimedia i dial in an empty fm station and the speakerphone does the rest...wirelessly. Its a pretty solid connection as well, not fuzzy sound like the similar old school wired connection...my 2 cents...
