Vibration at stop light and clicking sound in engine
Old Apr 4, 2010 | 08:58 PM
bonjourbrat's Avatar
Hi all,
Hope someone can help with these two problems:
First is when I'm stopped at a light or stop sign, when in D, the car vibrates a fair amount, but when I shift to N, it stops.
Is that a confirmation that its the right engine mount that's cracked?
http://www.finishlineperformance.com...21-06-1559.pdf
Second, with the hood open, I can hear very faint clicking (arching) sounds, seem to be from the ignition coils area. Is that a sign of coil dying? Should I change spark plugs or coils first?
Old Apr 5, 2010 | 10:51 AM
Go48's Avatar
Check the plugs and plug wires. Make sure the plugs are screwed in tight and that the wires are tight on the plugs and coils. Either one can create the clicking sound and possibly cause the idling problem.
Old Apr 5, 2010 | 12:46 PM
mannerofspeakin's Avatar
Originally Posted by bonjourbrat
Hi all,
Definitely sounds like motor mounts on the vibration part. Coils, plugs for arcing sound. Best to replace coils and arcing first. A little cheaper and may, a slight chance, rectify your vibration issue.
Old Apr 6, 2010 | 05:29 PM
Thanks for the help and advice! Will go get it checked out
Old Apr 14, 2010 | 04:46 PM
New plugs and plug wires did it! No more vibs or misses
Thks Guys!
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
Skyl3r
Dec 2, 2019 04:51 PM
T_Mags
Jul 24, 2015 11:29 AM
ironj221
Jul 16, 2015 10:16 PM
