Clutch and Transmission issues
Old Apr 2, 2010 | 04:45 PM
GeistRx8's Avatar
Ok, well I have an 04 standard tranny, the engine and clutch where replaced about 3000 miles ago. Now my clutch pedal seems to be getting almost sucked to the floor when i press it in. Really there is very little resistance from the pedal at all. Letting the pedal out the clutch engages fine i just can not seem to figure out what is causing the clutch to do this?? Also there is a slight shutter only when taking out coming from the tranny any thoughts thanks.
Old Apr 2, 2010 | 05:56 PM
mzrx's Avatar
did the installer bleed your clutch after the install? It may just need to be bled. I had a similar issue when I changed out my clutch.
Old Apr 2, 2010 | 07:52 PM
GeistRx8's Avatar
Yeah i am thinking that may be it i was just getting a broad range of thing to maybe try this weekend thanks
drebbrnator
Dec 27, 2018 07:02 PM
Dokuji
Nov 1, 2016 02:51 PM
BigMikeATL
May 26, 2016 12:31 AM
