Nut & bolt checklist
Old Apr 2, 2010 | 08:19 AM
BlueRenesis82's Avatar
Registered Tracker
Hey, getting my car ready for my season opener next weekend, and I am doing my own tech. I know to check the brake fluid, lugs, oil level and sway bushings. Are there any other areas that I should be checking/lubing/gazing lovingly at? If anyone has a list that would be super.
Old Apr 6, 2010 | 11:37 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
I'm doing a Time Attack this weekend as well. I'm looking over the following:
Oil Change
Seafoam
Top off Coolant
Top off Brake/Clutch fluid
Top off fuel
Rotate Tires
Tighten Lugs
Tighten Strut Bar
Look over Oil Coolers
Look over brake rotors/pads
Look over motor mounts
Clean out the interior except for necessities
Old Apr 7, 2010 | 08:18 AM
Registered Tracker
Oil Change
Seafoam
Top off Coolant
Top off fuel
Rotate Tires
Tighten Lugs
Tighten Strut Bar
Old Apr 7, 2010 | 11:41 AM
seafoam, lol
it's a good idea to keep a handful of plastic rivets and screws for the front under tray around
Old Apr 7, 2010 | 03:02 PM
L337fpc's Avatar
ლ(ಠ益ಠლ)
Good call. I'm going to grab some tonight from the dealership.
Old Apr 7, 2010 | 06:05 PM
bse50's Avatar
#50
Never forget the zipties!
Check your spark plugs btw, especially if they're "old".
Old Apr 8, 2010 | 05:29 PM
Registered Tracker
No offense to everyone with the help that they have offered, but what I was really looking for was something like this:
Brake caliper bolts 40 lb/ft
Grease brake slider bolts
etc
etc
Old Apr 9, 2010 | 01:56 AM
You should have already done that stuff
Old Apr 9, 2010 | 05:11 PM
Registered Tracker
Perhaps you missed the point where I said I was doing my own car maintenance. Since I have not found a list that is specific to RX-8's, I was hoping that someone else had already constructed one.
Old Apr 10, 2010 | 02:01 AM
StuttgartRX8's Avatar
Nurburgring Camera Whore
I don't use a list but every year after winter, I start at the front of the car and I check everything I can get to til I'm to the back of the car. I check for leaks, damaged parts, and etc. This year it has taken me about 10 hours to completely finish the car that includes replacing parts. I could make you a list but it might be overkill for you. I'm just super cautious since I will probably do over 1000 track miles this year.
Old Apr 10, 2010 | 07:46 AM
moremazda's Avatar
shookmotorsportsdotcom
Do you have a copy of the FSM yet? Go through the suspension (and brakes) with a torque wrench. All of the numbers for the systems are in the back of their respective section of the FSM.
Old Apr 18, 2010 | 08:24 AM
SilverEIGHT's Avatar
Hey blue... one thing that you really need to tighten are large bolts that hold the trans/diff to the PF (power frame). You have 4 on the front and back. If these get loosened you can have problems shifting due to the angle change. Not sure the size but make sure these are tightened in the 90# torque range.
Mine got loose one time and I lost one of the nuts. Shifting went to hell.
Also make sure the sway bar nuts are tight. I take the brackets off and grease the bushings first though.
You need to come back down to Road Atlanta and run with us again.
Old Apr 18, 2010 | 09:39 PM
Registered Tracker
Thanks for the tip!
I would love to come back, but since I got married, it would be nice to be able to go on a honeymoon. Gotta keep the wife happy.
Old Apr 21, 2010 | 07:39 AM
L8APEX's Avatar
Smooth Criminal
I check all the suspensions mounting points, sway bar endlinks, run my fingers along the braided brake lines looking for bumps or tears, and have added an alternator belt to my box of track gear, just in case it breaks, they are not common, and can ruin a weekend.
Old Apr 21, 2010 | 05:27 PM
Registered Tracker
Has anyone in your group had issues with that belt?
Old Apr 22, 2010 | 05:57 AM
L8APEX's Avatar
Smooth Criminal
yep, at CMP in February, OnRails had his let go early on Saturday, never found it, but it sidelined him for the rest of the weekend, because the only parts store around had to have it sent in from another store, and it would arrive on Sunday.
It is not an expensive belt, but it could ruin a weekend, why not have one around.
Old Apr 22, 2010 | 02:18 PM
whoneedspistons's Avatar
^agreed..
Old Apr 22, 2010 | 09:38 PM
olddragger's Avatar
i melted mine at Road Atlanta one summer---no joke--i have witness's!!!
That alternator get hot. Yea it does.
Add belt tension to you prep list
once a year i change diff and trans fluids
i change coolant
i do a complete brake fluid flush including the slave/master cylinder
check the brake caliper piston seals
check exhaust header bolts
check omp for leakage and line integrity
clean the maf and the eccentric shaft sensor
clean the wheel hub mounting surfaces--buildup can happen there.
check the roll bar end links----most people are surprised that binding is occurring there because the rubber seal cracks and there is no lube left
I guess I will stop here-----you asked !
OD
check ppf adjustment and all exhaust bolts
after the car is 5 + yrs old it may be wise to replace radiator hoses
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
He||hammer
Sep 29, 2015 09:40 PM
WingleBeast
Sep 9, 2015 10:10 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
