View Full Version : Header / Midpipe Gasket Question
learycd
03-29-2010, 08:58 PM
so definitely have a leak between my midpipe and header. I reused the crush gasket (it look like it was in good shape). My question is, has anyone tried using a 3 bolt crush gasket like this one instead?
http://raceroots.com/index.php/products/mazda/rx8/exhaust/high-performance-exhaust-gasket-3-bolt.html
or the remflex product
http://catalog.remflex.com/FORD_Header_Exhaust_Manifold_Gasket_p/pt55-002.htm
they look kinda similar?
so i guess the question is, do they work better?
thanks guys
learycd
03-30-2010, 09:01 AM
no one has used this type of gasket??
learycd
03-31-2010, 03:46 PM
anyone with ANY insight? i really dont wanna waste 30 bucks for no reason
nycgps
03-31-2010, 09:49 PM
The only gasket thats re-usable is the Engine to Header Gasket, and of course it has to be in good shape.
All other gaskets should be replaced
quazmosis
03-31-2010, 10:17 PM
I'll second that.
The Reverend
03-31-2010, 10:22 PM
I just picked up the gasket from Race Roots for this exact reason. I'll let you know on Friday how it works
Jon316G
03-31-2010, 10:26 PM
Me and another local use that gasket.
It was supplied with our MazSport midpipe.
Works great and never had a problem reusing it.
I keep the OEM gaskets on my cat for when I need to swap it for e-check.
olddragger
04-01-2010, 09:30 AM
you can reuse it but be very careful---the carbon becomes fragile after being crushed
it works but i still have to retighen my collector bolts from time to time.
Damn that Ford gasket looks just like it!
nycgps
04-01-2010, 11:57 AM
I dont understand ...
people can afford mid pipes and other crap. but they just being cheap on buying a new gasket ?
I dont understand the logic behind this ... seriously ...
learycd
04-08-2010, 10:18 PM
just as an update, i got my old cat out and measured the bolt pattern, this gasket from remflex WILL FIT the rx8 flange
http://catalog.remflex.com/COLLECTOR_CONNECTOR_Flange_Exhaust_Gasket_p/rf8046.htm
...and being cheap and throwing money away are two different things!
learycd
04-08-2010, 10:20 PM
i just ordered mine from remflex, its the same one. would love to hear how it works
silverbullet05
04-14-2010, 04:15 PM
just ordered the same remflex gasket for an exoticspeed cat. hopefully if fits!
learycd
04-14-2010, 05:16 PM
it should fit, if not u can easily use a drill bit to open the hole 1/16 of an inch or so!
silverbullet05
04-15-2010, 10:16 AM
great to hear. did you happen to use any other gaskets from them for the rest of the exhaust?
silverbullet05
05-03-2010, 09:45 AM
got the remflex 3 bolt gasket installed. fit like a glove and since it came as a 2 pack i have a spare if i ever need it =)
Thanks again learycd
learycd
05-03-2010, 10:16 AM
no problem, def seems like the better deal out of the two, especially with the two pack
all my suby buddies swear by these the brand too, fixed all their leaks (turbo, cat, exhaust)
