A/C Amplifier
Old Mar 29, 2010 | 06:59 PM
kwells123's Avatar
A/C Amplifier
I was wondering if anyone knew where to locate an AC amplifier. I'm having the problem where the AC only stays on for about 10 seconds at a time and then shuts off. I've had no luck trying to locate one online. Does anyone know how much that part usually costs?
Old Mar 30, 2010 | 03:44 AM
ReyRey's Avatar
Zoom Zoom... Real Talk
Easy way to do it is talk to your local Mazda dealer service department. Alot of them are happy to help with giving schematics and then share the insane cost to replace it.
Old Mar 30, 2010 | 07:12 PM
Junk yars is your friend.
Also search this DIY section. You may be able to fix it.
Old Apr 2, 2010 | 12:41 PM
aim9's Avatar
theres a tsb for that... so if your still under warrenty its free at your dealer other wise heres a link to a file with a image and all the info for the amplifier(looking at it my self its way too expensive)
http://www.coremazda.com/forums/mazd...k-cooling.html
Old May 12, 2010 | 04:11 PM
04Green's Avatar
Moder8
#26
04Green
04Green's Avatar
Found this on the GA site. The procedure worked, will test tomorrow as well.
Yeah, I know, I changed two things at once. However, the fan mod was more to be kind to the engine until I can afford a MM Cobb. I need shocks and springs to catch the bigger porches more than power.
The program your AC link from Glyphon on the GA club site.
http://garx8club.com/v3/viewtopic.php?f=21&t=294
The process:
To improve the performance of your A/C do the following:
1. Make sure the car is off AND the HVAC fan is off AND the A/C on/off button is off.
2. Press and hold the front defroster (on the left) AND air source (bottom) buttons
3. Continue pressing the buttons in step 2 and turn the key to ACC for 3 seconds
4. Continue pressing the buttons in step 2 and further turn the key to ON (NOT START) for 3 more seconds.
5. Verify the programming update by observing the REAR defroster LED blink 3 times.
6. Release the two buttons from step 2 and start the car.
When you turn on the A/C with the MODE button set to FACE and turn the thermostat to full COLD (max counter -clockwise setting) the RECIRC should automatically engage. In addition, the amplifier should put out colder air (~ 5-10 degrees F colder and not just from the RECIRC setting) and the compressor will not cycle nearly as often (which some of us found annoying).
Note: This programming change is not persistent. If the battery is fully discharged or disconnected the procedure needs to be repeated to re-enable the settings.
(quick note, hold the buttons with your left hand, turn the key with the right)
Old May 12, 2010 | 07:12 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
^...............some of us know about this and have used it with success. There's a couple of threads with this embedded in it.
RevMeHarder
Jun 1, 2026 02:30 PM
nadodave
Aug 28, 2019 05:55 AM
Learners_Permit
Sep 27, 2015 07:38 PM
djp6783
Sep 19, 2015 12:12 PM
mazdaverx7
Jul 21, 2015 07:31 PM
