car jerks really hard and sometimes just looses all power
Old Mar 28, 2010 | 08:39 PM
FoxRacer600RR's Avatar
120,000+ miles tick tock
ok, as tittle states the car will be operating properly then will kind of hessitate as i slowly accelerate then if i go WOT it will pull real hard but once it reaches a higher rpm ( no certain rpm) it just looses all power and the rpms drop to idle (and sometimes just cuts off)before it will rev or accelerate again. just feels like if i was driving and just turned the key off. but after a while on very easy driving it will stop and i can rev to redline without a problem, it has been like this ever since i moved to FL from WV ........car is very well maintained oil changed every 2000 to 2500 miles, spark plugs are less than 2300 miles old coils are the same age, 93 octane used ever since the car was purchased with 40000 miles, 95000 miles on the car now, CAI, no cat,driven 60/40 hard/casual.......anybody have any ideas?
Old Mar 28, 2010 | 09:47 PM
bumblebeerx8's Avatar
Rear Mount GT35R
have you tried removing the + battery terminal and all the resets sounds like the trims are all out of wack or front 02 is bad/ maf needs cleaned
Old Mar 29, 2010 | 01:04 AM
jasonrxeight's Avatar
probably the MAF is going
Old Mar 29, 2010 | 05:51 AM
@!!narotordo's Avatar
FLAME ON!
Sounds like its in limp mode and you need a new engine. Thats what my AT did when I lost the engine.
If you dont have a cat then its not clogged and thats ruled out.
If you changed the spark plugs wires and coils less than 30k miles thats ruled out.
Do you run the gas tank down to E? could be fuel pump.
Any CEL?
Compression test?
Just for fun, what other mods do you have on the engine?
Old Mar 29, 2010 | 12:15 PM
heyarnold69's Avatar
Rotary wanabee
has it been raining ? dirty maf get some maf cleaner
Old Mar 29, 2010 | 08:10 PM
This is not a 2009 or newer car.
BAD coils, Clogged CAt, bad fuel pump
Old Apr 1, 2010 | 09:36 PM
Rotary wanabee
get midpipe / clean maf / replace coils / seafoam engine ... check ssv valve / clean throttle body / reset ecu ... choose many of the above lol
damm you fuel pump! bhr pump = nice
Old Apr 5, 2010 | 09:12 AM
SheffieldSteel's Avatar
Intended acceleration
This would probably get a better response in the Series I forum
Jesus Martinez
44
May 6, 2025 08:09 AM
Skyl3r
Dec 2, 2019 04:51 PM
harithac
Jul 25, 2015 04:21 PM
dbarber
Jul 25, 2015 01:34 PM
Majictoast
Jul 18, 2015 06:45 PM
