MAF plug wires too tight?
Old Mar 28, 2010 | 02:34 PM
limpbozkit's Avatar
Gets the WORST mpg
Correct me if I'm wrong but in the image below is a picture of the Mass Airflow Sensor. The plug-type connector and wires coming from it are very tight. Almost to the point in which it feels like they have constant tension on them, especially the red wire at the top. I may just be paranoid here but I was hoping someone else who reads this could check under their hood and feel to see if they too have very tight wires here.
Old Mar 28, 2010 | 04:16 PM
lilring's Avatar
Finally a MT
dude.. that isnt the MAF.. that picture shows the Drive by wire system for the throttle body.
Old Mar 28, 2010 | 05:01 PM
tza0001's Avatar
Dum Spiro Spero
^+1! I do not understand your concern. So what if the wires are tight? I prefer my wires being tight rather than loose)
Old Mar 28, 2010 | 05:14 PM
limpbozkit's Avatar
Gets the WORST mpg
The wire is really tight and the concern being with engine movements and normal driving it seems like the wire could be pulled from the plug body and cause a problem?
Old Mar 28, 2010 | 05:22 PM
tza0001's Avatar
Dum Spiro Spero
Hmmmm. I see what you mean. I will go check how mine looks and I'll let you know.
Old Mar 28, 2010 | 05:27 PM
tza0001's Avatar
Dum Spiro Spero
Mine looks the same. A bit tight I would say.
Old Mar 29, 2010 | 01:00 AM
limpbozkit's Avatar
Gets the WORST mpg
Thanks for checking. I just wanted to make sure it was like that from the factory and not something I did when replacing my plugs, wires and coils or installing the intake.
Old Mar 29, 2010 | 05:38 AM
@!!narotordo's Avatar
FLAME ON!
Mine was like that then I put a zip tie on it. When I pop the hood people are like wtf? what are you doing but I fig better safe than sorry
Old Mar 29, 2010 | 08:57 PM
Please take an automotive class and let the mechanics work on your car.
Old Mar 29, 2010 | 09:44 PM
lilring's Avatar
Finally a MT
lol.. Im always for hire
Old Mar 30, 2010 | 09:39 AM
limpbozkit's Avatar
Gets the WORST mpg
If I let someone else work on my car every time I needed something done I wouldn't learn anything now would I?
Now, go check under your RX-8's hood and feel the tension on the pictured wires and compare it to any other connector's wires under the hood and you should see why I asked the question in the first place. All the other connections have a small amount of wiggle room.
Old Mar 30, 2010 | 09:54 AM
Huey52's Avatar
Registered Zoom Zoomer
I just cleaned my MAF this past weekend and the wire to the connector is not overly tight. No real slack but no adverse strain either. '05 here.
edit: oh, now I see your picture. As indicated that's the drive-by-wire throttle connector, not the MAF (which is on the intake tube). But regardless, I think what you mean is that the cable needs some additional strain relief. Just use a tie-wrap if you're that concerned.
Old Mar 30, 2010 | 11:25 AM
heyarnold69's Avatar
Rotary wanabee
my wires aren't that tight ... weird ...
maf sensor is closer to the front of the car
uZu
Dec 30, 2015 12:35 PM
TeslaMSI
Dec 10, 2015 01:10 AM
mattymack
Sep 6, 2015 10:33 PM
