optima red top
Old Mar 28, 2010 | 01:38 AM
kennyt2001's Avatar
optima red top
I recently changed my battery in my rx8 from a duralast that died in less than a year and a half to a optima red top. since that change i find it harder for my car to fire off. the optima definetly spins the motor great but it seems that i have to hold the key longer to start, and most of the time it sounds like it bearly has enough to fire it off. What may cause this?
Old Mar 28, 2010 | 03:25 AM
Look, it's really this simple. Your battery cranks the starter, period. If the starter cranks good, but the car us slow to start then it's something else; low compression, bad plugs, bad plug wires, bad coils (please spare me the xxx coil change BS, I'm making more power NA on factory coils than you can have the biggest wet dream fantasy of your life over)
Old Mar 28, 2010 | 04:33 AM
@!!narotordo's Avatar
FLAME ON!
Anything with xxx in it = biggest wet dream, thats where you get your power
Old Mar 28, 2010 | 05:59 PM
Socket7's Avatar
ಠ_ಠ
Sigh.
Basic questions need to be asked before we can answer anything.
What year is your car? (you could have the crappy old starter if your car is old enough)
How many miles does it have?
What is its service history? (When did you last change coils, plugs and plug wires?)
Team RX8 is right. The battery just spins the starter. If the starter cranks properly instead of slowly, your problem has nothing to do with the starter or the battery.
Old Mar 28, 2010 | 07:07 PM
tza0001's Avatar
Dum Spiro Spero
^+1! Does your car start better when it is cold rather than warmed up?
Old Mar 29, 2010 | 01:01 AM
kennyt2001's Avatar
Originally Posted by Socket7
Sigh.
2004 rx8 ( got updated starter)
132,000 miles
changed coils plugs and wires at 100,000
Old Mar 29, 2010 | 01:02 AM
kennyt2001's Avatar
yeah i would say it starts a little better when its cold
Old Mar 29, 2010 | 01:10 AM
jasonrxeight's Avatar
132,000 miles
132k miles? original engine?
Old Mar 29, 2010 | 01:12 AM
kennyt2001's Avatar
yes sir, original engine, i would say 80% is highway milage
Old Mar 29, 2010 | 01:26 AM
still can get extended warrenty?
Old Mar 29, 2010 | 03:17 AM
kennyt2001's Avatar
Are you asking me if I can or if there is an extended warranty after 100k
Old Mar 29, 2010 | 05:31 AM
FLAME ON!
Extended warranty = wast of money. Send me the $3,000 lol extended warranty plays off the manufacturer warranty.
Lets try this:
When was the last time you changed your spark plugs? and spark plug wires?
Also depending on how you drive, you will need to change the spark plugs coils and wires about every 40k miles.
Take your 8 to autozone or checker and ask them if they can check your cold cranking amps on your red top. They can also tell you how many volts your at during idle and if your starter is going out or weak.
If all checks out good, have a compression test done.
GL
Old Mar 29, 2010 | 10:43 AM
tza0001's Avatar
Dum Spiro Spero
First of all congrats on your mileage and wish you many more miles to come! In terms of your problem this is what I would do:
Make sure your battery is fine. Since you changed your spark plags, wires, and coils at 100,000 miles it is time to do it again. I would also suggest you to decarbon your engine with Seafoam or Zoom Zoom cleaner. A compression test would also be helpful so you know where your engine stands.
Old Mar 29, 2010 | 11:12 AM
Nubo's Avatar
Lubricious
Are you saying you noticed harder starts just as soon as you changed the battery?
Old Mar 29, 2010 | 05:35 PM
Socket7's Avatar
ಠ_ಠ
If it's harder to start when it's hot, I'd get a compression test before changing out coils plugs and wires. They could be bad after 34k, but with a motor that's over 100K, there are other likely culprits to check first. My reasoning for a compression check first is that it would be cheaper then new plugs wires and coils and it tells us something about the health of the engine. It could be new engine time, or it could just need a Seafoam treatment if you're lucky.
Congrats on making it over 100K miles btw.
Old Mar 29, 2010 | 06:15 PM
heyarnold69's Avatar
Rotary wanabee
have we checked the grounds?
Old Mar 30, 2010 | 04:47 AM
FLAME ON!
Good one. But I never heard of grounds just going bad unless someone was messing with them.
05rx8mazda
Nov 28, 2015 09:42 AM
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
