wheel hopping
Old Mar 26, 2010 | 11:19 PM
viperbites's Avatar
KY wheel hopping
anyone having trouble with this? what can be done to fix the problem. thank you for taking the time to read and answer new member and first post 05 rx8 owner
Old Mar 26, 2010 | 11:43 PM
Old Rotor's Avatar
"KY" ?? what are you doing when you get wheel hopping?
Old Mar 27, 2010 | 12:10 AM
kersh4w's Avatar
Hit & Run Magnet
are you drag racing?
Old Mar 27, 2010 | 05:44 AM
viperbites's Avatar
KY
just hard take off where it should just spin a little it will wheel hop it even wheel
hops in 2nd and 3 gear from time to time
Old Mar 27, 2010 | 05:46 AM
viperbites's Avatar
KY
nah no drag racing i have a z31 with a 383 stroker in it for that
Old Mar 27, 2010 | 10:02 AM
zoom44's Avatar
traction control. turn it off.
Old Mar 27, 2010 | 11:02 AM
shazy's Avatar
I changed my tires and I had no more wheelhop.
I still went with OEM because I got an amazing deal for all 4 of them.
Old Mar 27, 2010 | 04:18 PM
viperbites's Avatar
05 mt it has no traction control that i know of
Old Mar 28, 2010 | 05:06 AM
check again. after that tire pressure.. less is more.
Old Apr 30, 2010 | 02:01 AM
Lavious's Avatar
I just recently encountered the same issue. Incredible wheel hop during a burnout. Granted I have had the car for 2 years and this was the first time that I've experienced anything like this. I normally play with the car around corners as I should...not stoplights. I wonder how much of a factor does temperature make? It was in the 50s. (17k miles on stock tires @ 31psi) From my searching this seems to happen to many IRS cars at any given RPM. Other than the obvious...'stop doing burnouts', any suggestions on how to keep the back tires planted firmly during a burnout?
Old Apr 30, 2010 | 02:08 AM
a change of springs and shocks did it for me. and dont do burnouts.
Old Apr 30, 2010 | 10:07 AM
yiksing's Avatar
the giant tastetickles
How to do a burnout if the tires are firmly planted?
theblinkof
Oct 4, 2023 05:24 PM
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
