Wierd noise in rear end
Old Mar 26, 2010 | 08:30 AM
Captain1985's Avatar
Hi guys,
I'm hearing a wierd screeching/clunking noice coming from the rear end of my car. I just had new rotors put on a couples days ago so there may be something rubbing?
Also when I'm on the expressway I feel a slight wabble, nothing too crazy, just not as smooth as it should be.
I just bought the car a week ago so it just went through a safety. I'm not sure if this is normal for the car to be riding like this.
Any suggestions would be a great help
Old Mar 26, 2010 | 09:59 AM
jasonrxeight's Avatar
Wobble could be wheel balance.
Jack up the car and spin the wheel in the air see what's making the sound.
Old Mar 26, 2010 | 10:03 AM
xun4gvn4everx's Avatar
True love is blue x2
The screeching/clunking noise sounds like the brake pad alert bar (I forgot the technical name). Basically it is a metal bar that extends from your rear brake pads that lets you know when they are getting low. So, your brake pads could be worn and/or something is off balance which is making the bar come in contact with the rotor (which goes along the lines of what you were stating about the other issue). Check your pads and check the wheel balance and the rotor balance. The rotors could have been put on off balance.
Old Mar 26, 2010 | 08:33 PM
nate340's Avatar
the brake pad indicator does not clunk, is the noise speed sensitive.
Old Mar 26, 2010 | 08:36 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Exclamation
Gotta get it in the air as said.
Oh..........I say check to make sure your lug nuts are tight.
Can you tell which side it's coming from?
Old Mar 26, 2010 | 09:34 PM
2tone's Avatar
The RX-8 is missed
i agree, tighten down the lugs and make sure the wheel is properly mounted. sounds stupid, but it happened to me!
New Yorker
40
Mar 22, 2022 06:01 AM
ColeParkerrr
Sep 15, 2015 07:30 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
Bill_Monteith
Aug 18, 2015 07:11 AM
Belalnabi
Jul 17, 2015 07:48 PM
