Odd question regarding wheel caps on Kosei wheels...
Old Mar 25, 2010 | 09:30 AM
Neo's Avatar
Neo
I am The One!
Hey guys,
I'm looking for a solution all the way out in left field.
I recently got some Kosei K1 TS's. The center cap that comes with these wheels is a little tacky. I never liked it. My plan was to obtain the wheels, but change the center cap.
I never realized how much of a chore this would be.
As it turns out, Kosei doesn't use a standard size for its center cap.
The wheel itself relies on the cap to be inserted from the inside before mounting it onto the hub. From what I can see it's got a little indent on the wheel where the center cap sits against.
I bought some Mazdaspeed center caps hoping they would fit without any modifications. That was too good to be true. The entire cap fits within the hole. It's about 2-3mm's off from being able to sit against the little dent.
My question is, does anyone know of an elegant solution to this problem?
I've attached the pics of the wheels and caps I've been talking about.
I want to run the Mazdaspeed caps on these Kosei wheels.
Suggestions?
Thanks,
Chris
Attached Thumbnails Odd question regarding wheel caps on Kosei wheels...-kosei_k1ts_s_ci3_l.jpg   Odd question regarding wheel caps on Kosei wheels...-mswheel.jpg
Old Mar 25, 2010 | 09:40 AM
Footman's Avatar
Dodging those Corollas
magic putty.
Old Mar 25, 2010 | 09:41 AM
Footman's Avatar
I don't see pics by the way
Neo's Avatar
Neo
I am The One!
Come on now.. seriously...
Old Mar 25, 2010 | 09:45 AM
Footman's Avatar
Ok, I see the pics now..
Neo, do you want a bandaid solution (i.e. one you just put on and never take off), in that case MAGIC PUTTY will do it..
Or.. do you preferred an engineered solution that allows you to take the cap on and off?
Old Mar 25, 2010 | 09:46 AM
Footman's Avatar
I also need to know, when you put the mazdaspeed centre cap on.. is there any wobble or play? Does it sit centre perfectly, just that the tabs don't latch on the back?
Old Mar 25, 2010 | 09:55 AM
Neo's Avatar
Neo
I am The One!
I would like a nicely engineered solution.
The cap itself doesn't come with tabs. It's milled out of aluminum. Outer diameter is probably 65mm, and then the inner circle, which holds 2 sets of rubber rings, is about 60-61mm.
There are no tabs.
The little tab on the wheel it has to sit against is probably 6-8mm's away from the inner circle of the cap.
I think I might have to get something fabbed up.
Old Mar 25, 2010 | 10:02 AM
Footman's Avatar
Does the cap sit exactly centre right now, or is there play around the edge?
Old Mar 25, 2010 | 10:05 AM
Neo's Avatar
Neo
I am The One!
The cap right now fits within the hole of the hub. But it's a little tight. Since it's got rubber rings it tends to sit in if there's pressure, but then you let go and it twists a bit out.
I don't want it to sit on the hub though. I want it to sit on the wheel itself. Which is probably the safer way to go, right?
Old Mar 25, 2010 | 11:42 AM
Thumper3322's Avatar
hey least yours comes with center caps even tho they are tacky. Works doesn't make them, how gay is that!
Need someone that is able to make them specific, least that's what I need
Old Mar 25, 2010 | 12:25 PM
Neo's Avatar
Neo
I am The One!
Damn.. yeah, I heard certain wheels from manufacturers don't come with caps.
That's gotta suck.
I've been reading about some crazy work arounds for center caps though... I'm sure you'll be able to find something.
I think I've got everything I need. I just overlooked a few things. I hope to try it out tonight. But we'll have to wait and see.
Old Mar 25, 2010 | 12:42 PM
2hit6's Avatar
I encounter this issue when I purchase Rota Wheels for my old Mazda3. What I end up doing is removing the metal sticker off of the rota center cap and replaced it with a custom gold mazda symbol on black background logo printed on a car sticker-like material...
You could take the same approach but have 'mazdaspeed' logo be printed on a thin metal sheet and replace it on the original Kosei center cap....the wonders of Adobe Illustrator!!!!
Just a thought....
________
Kitchen Measures
Old Mar 25, 2010 | 12:56 PM
Footman's Avatar
The mazdaspeed logo isn't actually just a sticker/logo though on the centre cap. I had them before. It's something that has a thick laminate plastic coating on top! Very nice!
Old Mar 25, 2010 | 01:02 PM
Neo's Avatar
Neo
I am The One!
2hit6,
Yes, you could do this if you wanted to use the center cap that came with the Kosei wheel. The thing is, I'm not fond of the actual cap. The logo I could care less about. It's the actual cap that I have a problem with.
The Mazdaspeed cap is made out of solid aluminum and the "sticker" is laminated really nice. It will stand the test of time, no doubt.
Just gotta take a look and see if I can fit it somehow. There's going to be a bit of trial and error, no doubt.
Old Mar 25, 2010 | 01:08 PM
Footman's Avatar
You can try for a tension fit using rubber tubing that's cut and lined around the circumference. like a grommet
Old Mar 25, 2010 | 02:09 PM
Neo's Avatar
Neo
I am The One!
I'll make sure to get a few people together for this.
Thanks for all the suggestions.
amshaw
RX-8 Multimedia/Photo Gallery
10
Aug 26, 2015 08:50 PM
Kahl
Aug 20, 2015 11:49 PM
M RX 8
Aug 5, 2015 06:45 PM
nnsoch1776
Jul 22, 2015 04:16 PM
