Custom axle-back help
Old Mar 23, 2010 | 09:34 AM
kwikslvr's Avatar
Rotary User
i've been tossing this idea around as well. i've looked at many of the catbacks for sale and it seems as though they are not much more than a couple coffee can mufflers with a splitter and some tips. i think this is something that could be done for under 200 dollars. im just worried about how ricy / raspy it might sound.
Old Mar 23, 2010 | 10:15 AM
paulmasoner's Avatar
Asshole for hire
you're not going to find anything remotely in your price range that will not sound like total **** on a rotary engine. for anything tolerable you're going to have to fork up for an aftermarket catback, or fork up for a properly thought out custom setup.
go ahead and buy a couple of coffe cans and do it the junkyard way. I'll warn you though when you come back here with reports of how bad it is, or how unhappy you are - you'll get stfunewb'd and told you should have read/searched first. you arent the first one's to have this idea, and theres a reason that the known branded catbacks are what sells. 1) convinience, the driving force of our culture 2) cost, 99% of ppl cant "make" anything of comparable quality for even close to the same cost
Old Mar 25, 2010 | 10:08 AM
alnielsen's Avatar
Originally Posted by BoardSnow6
I know how rotarys burn alot hotter than any other engine... Would it melt a glasspack or ruin the welds on say a cherry bomb vortex? Im curious of how it would sound. You may say it sounds like total **** but can you define that?
Even piston engines blow out a cherry bomb. Rotary engines need a stainless steel packing to survive the heat. The heat isn't hot enough to melt welds.
Old Mar 25, 2010 | 10:10 AM
Asshole for hire
I'll partial quote something i just posted elsewhere...
Originally Posted by paulmasoner
i get temp readings from the cat section of the pipe(secondary O2 sensor)............
i regularly see cruising temps of 940 CELCIUS, and i've seen it get very close to 1,000C under harsh conditions. the OE cat wont take that. In fact the ONLY cat anyone has found(and mentioned) that will handle that kind of repeated heat is made by HJS, and sells for $1,000-1,500 depending on the current exchange rate.
1,000 degrees Celcius. thats the kind of consistent thermal abuse anything you put in the exhaust stream should be able to handle.
as far as sound, noone can define that in any tangible way. but 99%+ of ppl here say the same. if you search you may be able to find old links to sound clips of ppl who have tried this sort of thing in the past. check youtube etc as well. even then, remember that without a proper full range microphone recording, and speakers playing - that you're not hearing the full spectrum of what any particular thing will sound like
Old Mar 25, 2010 | 10:18 AM
silverbullet05's Avatar
thought about it too, and decided that i will be holding out for a used borla or even a greddy. lol
i've had custom exhaust on my other cars, but i won't chance it with the 8.
Old Mar 25, 2010 | 10:32 AM
Asshole for hire
sorry man, but your only real options are:
1) listen to what ppl here say and go off that.
2) try to judge as best as possible off sound clips and go off that
3) try what you will and find out for yourself
Old Mar 25, 2010 | 10:34 AM
OBX, $300 shipped if you want a decent catback on the cheap. Read the reviews. Or do like I did and just get a mid pipe and aftermarket tips welded on. Car sounds good, makes power (catbacks don't) and in looking at my exhaust I have pretty Magnaflow tips
Plus I love the smell of fuel in the morning
Old Mar 25, 2010 | 10:40 AM
Asshole for hire
^^ not a bad idea. i have the MS catback and gutted OE cat-pipe for the moment. the catback does nothing for ya. cat removal doesnt do a whole awful lot(power wise), helps if you tune adjusts for it, but not much.
Old Mar 25, 2010 | 10:49 AM
TX
Yeah, when I say power I mean 5-10HP at best on the butt dyno. I'm almost done with my reliability mods so tuning VIA the AP is my next step. But, a stock 8 or an 8 with a catback and intake is no match for me. Chalk it up to the midpipe, BHR kit, and my awesome driving skills
But honestly I just maintain my car very well and I think that is the most important thing, just to make sure she is running up to her potential.
Old Mar 25, 2010 | 10:50 AM
Asshole for hire
bit more sound is easy. test pipe. resonated mid-pipe. catback. or combination of the aformentioned
Old Mar 25, 2010 | 10:52 AM
Asshole for hire
same here, my MAF tells that i am making ~230 at the fly so roughly 195-200 at the wheels. no intake/exhaust in the world will get you there without tuning
Old Mar 25, 2010 | 10:56 AM
Asshole for hire
http://www.cherrybomb.com/products/extreme
who knows? i imagine it'd be hard to find specs on their "aluminized steel" to be able to say anything about its quality, far as sound.... find a clip and judge as you can, or buy it and try...
Old Mar 25, 2010 | 11:04 AM
I am debating glass packs at the moment. I have heard old school rotaries running them back in the day and it sounds great. But i have read that they melt but I have never seen evidence of that.
Old Mar 25, 2010 | 11:08 AM
There was a guy the other day who posted here with a clip of his dual glass pack setup. I will search for it.
