20B Engine Code D599 - 100-120+ psi all rotor faces!
Old Mar 19, 2010 | 09:47 PM
Juiceh's Avatar
IL FS: 20B Engine Code D599 - 100-120+ psi all rotor faces!
This engine was pulled from a running car. Sean from A-spec Tuning will vouch for that.
It is a late model D series #599. One of the most sought after and hard to find 20b engines.
I do not know if it was ported. It could be but I really don't know.
Stock turbos & manifold can be included if buyer wants them.
The rotor housings are polished along with the UIM alternator, front cover & oil fill neck and some of the accessory pulleys and brackets. All the polishing could use a once over.
Some of the side plates are painted orange, so is the LIM. One of the Irons is yellow. The coolant necks are painted blue and the water pump housing black. I dunno what the deal is with the color scheme it was done by a previous owner. I was gonna rebuild the engine and repaint everything with a different scheme.
Compression test videos:
Front Rotor - 110-120+ psi:
http://www.youtube.com/watch?v=rK6lBJDX-Sk
Middle Rotor - 110-120+ psi:
http://www.youtube.com/watch?v=msuu1C3_0w0
Rear Rotor - 100+ psi:
http://www.youtube.com/watch?v=69pE8bifI3E
As you can see, it is a perfect candidate to be dropped in as is for a budget build with no tear down of the engine needed and it is also a perfect engine for a big dollar rebuild to whatever crazy specs you want.
Why gamble with a JDM junkyard engine?
$5000 Shipped to contiguous united states ONLY!
I am a member of the Rx7Club and just now thought to post this over here too.
All the info to verify who I am can be found here:
http://www.rx7club.com/member.php?u=58083
Old Mar 19, 2010 | 10:29 PM
pdxhak's Avatar
Official Post Whore
On 7club your FS thread is $5k shipped CONUS and here you are charging for shipping. It would be a good idea to make the threads the same. Great motor. GL with your sale.
Old Mar 19, 2010 | 10:44 PM
Juiceh's Avatar
My bad. I just copied and pasted the first post in that thread. I fixed it.
Old Mar 21, 2010 | 10:51 AM
Juiceh's Avatar
Old Mar 25, 2010 | 01:07 PM
Juiceh's Avatar
Ttt
Old Mar 25, 2010 | 05:33 PM
nvrfalter's Avatar
tonybob failpants
jeeeeebus i want ittt. **** being poor
Old Mar 28, 2010 | 04:21 AM
cause the 20b swap is so eazy here!
Old Apr 1, 2010 | 07:56 PM
Juiceh's Avatar
Bump!
Old Apr 1, 2010 | 08:14 PM
tamz273's Avatar
How hard/easy is the 20b swap? Just out of curiosity.. And would you need alot more than just that engine?
Old Apr 2, 2010 | 12:00 PM
RWagz's Avatar
Piston-free 07.11.2007
Short answer: Yes.
Long answer: **** yes.
Still an awesome find for anyone already planning to do this.
Old Apr 13, 2010 | 10:30 AM
Juiceh's Avatar
Lets just say that it is a project that probably should be done by professionals and not a hobbyist in their back yard\garage. That doesn't mean it can't be done by someone who is very determined, but pretty unlikely to be completed by someone without alot of experience.
What you would need to go along with the engine depends completely on how you would want to run it. At the very least you need an ecu to run it, and that's if you are going to run it as is but naturally aspirated and a subframe if it doesn't fit without one. I'm not sure if it would mount as is, I don't think it will. Start going turbo and your going to need alot more, turbo, intercooler + piping fuel system, probably a beefier transmission to deal with the massive power and torque + all the goodies that go along with a turbo car.
Old Dec 7, 2010 | 06:32 PM
kish-mish's Avatar
is the engine still available?
Old Dec 10, 2010 | 06:38 PM
RxJaye's Avatar
I would KILL for this!!!!!!!!!!!
Old Dec 10, 2010 | 07:00 PM
shadycrew31's Avatar
WENTGERMAN
Didn't know you could use a piston compression tester for a rotatory that's pretty neat....
Old Dec 10, 2010 | 07:17 PM
mscamp02's Avatar
Blue Bullet?
I'm pretty sure I seen your car driving in lex a few weeks back out on new circle
Old Dec 11, 2010 | 04:56 AM
willnordacgreen1211's Avatar
04 NORDIC GREEN RX8
DO WANT. I NEEDZ MONEY glws
Old Jan 31, 2011 | 09:24 AM
Jamaalsmith's Avatar
Bump
you still selling that bad boy?
vapor2
Nov 3, 2020 03:38 PM
Rx808BI
Aug 9, 2015 10:06 AM
Ajmurphy85
Jul 30, 2015 07:51 AM
dbarber
Jul 25, 2015 01:34 PM
Bamaham
Jul 23, 2015 08:08 AM
