Vibration again what is it this time HELP!!
Old Mar 19, 2010 | 08:34 PM
Mr.We$t's Avatar
Rx-8 the protege
Ok so the vibe is back with a vengence! Just finished the Mazda zoom zoom engine decarb and everything went smooth? But now for some reason the car vibes alot more in drive at a stop light and when I turn the AC on it gets even worse now!
I just replaced
engine mounts
spark plugs
wires
cleaned the MAF sensor
Added
boost brothers header
rx-7 store mid-pipe
mazdaspeed exhaust
Old Mar 19, 2010 | 11:25 PM
Mr.We$t's Avatar
Rx-8 the protege
Bump
Old Mar 20, 2010 | 08:14 AM
Mr.We$t's Avatar
Rx-8 the protege
Bump
Old Mar 20, 2010 | 12:29 PM
xsnipersgox's Avatar
One Shot One Kill
errr... engine mount again? the dealer can easily figure it out. badly installed plugs?
Old Mar 20, 2010 | 01:16 PM
Mr.We$t's Avatar
Rx-8 the protege
I installed my own plugs using the DIY maybe I did somethin wrong I'll check on them!!
I also noticed that when the car is warm and I try and start it, it takes awhile to start then the RPMs drop really fast like they barely reach 1100 rpm then drop to 950 this is to weird!!
Old Mar 29, 2010 | 10:07 AM
Mr.We$t's Avatar
Rx-8 the protege
Ok so I tightened the spark plugs and the problem still lives on but now it's worse
When the car is warmed up and I put it into drive it will climb in rpm jerk forward then the rpms will drop to 950 and the car will vibrate like crazy any input or experience with this issue?
Old Mar 29, 2010 | 08:41 PM
There are two types of plugs. Did you install them correctly?
You have auto?
Old Mar 29, 2010 | 09:53 PM
Mr.We$t's Avatar
Rx-8 the protege
Red face
Yea an 05 auto
I jus took the throttle body out and cleaned it and the problem is still there!
When the car is warm it starts to vibrate really hard when In drive and reverse
Old Mar 29, 2010 | 10:08 PM
hakuna matata!
check motor mounts again
Old Mar 29, 2010 | 10:27 PM
Mr.We$t's Avatar
Rx-8 the protege
Is it a posibility that they installed wrong? It seems so simple just mount the and srcew the bracket back in! But I'll check em again 2marrow!!
Old Mar 29, 2010 | 11:01 PM
hakuna matata!
maybe they just failed again, if the problem is only happening when you're in a drive gear then that makes sense..
Old Mar 30, 2010 | 10:43 AM
zoom44's Avatar
bad coils
Old Mar 30, 2010 | 05:22 PM
Mr.We$t's Avatar
Rx-8 the protege
Question
Update: Checked mounts no cracks and the middle is still good!
I checked the coils with a timing light and they all were good the first time I checked it I wasn't sure if I did it right so I had my friend check em and got the same outcome and he said they were good!
When I put the car in drive the rpms jump really high then the car will jerk forward then it will vibrate really bad this is annoying me Im getting my plates 2marrow so I'll probly drive it to the dealer this weekend
Old Mar 30, 2010 | 06:34 PM
@!!narotordo's Avatar
FLAME ON!
Well tell you what, I had some where around 60k miles on my 8 seafoamed her and changed to synthetic oil. Started getting hard starts but could still wheel cherp 1st-3rd. The car would vibrate really bad. So I took her in to have a compression test done and what do you know. I need a new engine and I'm running on one rotor.
ironj221
36
Jan 20, 2026 08:28 PM
uZu
Dec 30, 2015 12:35 PM
GrAfiX
Aug 24, 2015 08:08 AM
R2D2X8
Aug 17, 2015 08:47 AM
arjunmshah
Aug 6, 2015 10:56 AM
