Rev to 4k Then Shut-off?
Old Mar 17, 2010 | 09:13 PM
RX22's Avatar
The Mazda service advisor told me today that every time I turn off the car to rev it up to 4,000 RPM, then shut it off with the revs up there. Any thoughts?
Old Mar 17, 2010 | 09:29 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
You do not need to do this unless the engine is cold(or not up to opertaing temp).
There are a ton of threads on this.
Convention wisdom here is that if the car isn't up to temp, then rev to 3k and turn the car off, otherwise, just shut it off(if warm).
Me.........I just go for a spin around the block when it's cold, even if I need to just move it for some reason.
Old Mar 17, 2010 | 09:39 PM
Easy_E1's Avatar
I never did it. Two 8's and 140,000 miles. Never flooded. That;s what the dealer is concerned with.
Old Mar 17, 2010 | 09:50 PM
jasonrxeight's Avatar
the dealer I go to always rev it then shut it off
Old Mar 17, 2010 | 10:19 PM
Silverisk8's Avatar
you only have to rev it still @ 3,000 or 4,000 rpm to warm it up, cause if you don't warm to mid temp. you're going to flood it
Old Mar 17, 2010 | 10:37 PM
Can't hurt. Just a good habit to get into in case there is a day when you have a brain fart and shut it off cold by mistake. I never shut my car off cold and I have the BHR kit and I still do this out of habit.
Old Mar 17, 2010 | 11:23 PM
xsnipersgox's Avatar
One Shot One Kill
no need, there is however a way to warm up the car enough so it won't flood that involves this though.
Old Mar 18, 2010 | 01:37 AM
Rotary-RX8's Avatar
Girls who drive stick FTW
If you do this procedure, and the needle isnt half way .. do you still shut it off,... cause i doubt reving it at 3k for about 10 seconds will make the needle reach half way... stupid question i know lmao
Old Mar 18, 2010 | 03:13 AM
xexok's Avatar
Someone correct me if I am wrong but the reason people rev to 3 or 4k when its cold and they have to move the car from say the driveway into the garage is because when you start the car theres more gas than is needed in the combustion chamber so it just clears it all out by reving? Hence why it can flood. So once you do that it *should* be ok to just turn off.
Old Mar 18, 2010 | 03:58 AM
WTBRotary!'s Avatar
Drummond Built
no it doesnt have to do with how much gas there is per say as to how rich the engine runs when Cold... but yes reving it to 3-4K Rpms then shutting it off spins the rich gas out to help prevent flooding.
Old Mar 18, 2010 | 04:40 AM
JessiahC's Avatar
Nitrous Threadjacker
Well, I think you're misunderstanding. Shutting down the engine while rev'd up to 3-4k
. It doesn't really have anything to do with the temperature of any fluids. I see where you're coming from though.
Old Mar 18, 2010 | 07:22 AM
Huey52's Avatar
Registered Zoom Zoomer
When not fully warmed and I need to shut down (which is rare) I rev to 3k, hold there for 10 seconds, and then shut down. In theory to dissipate excess fuel and thereby prevent flooding. Can't hurt, and I've never flooded.
Old Mar 18, 2010 | 07:31 AM
Silverisk8's Avatar
i always wait till the temp is half way then shut... never had a problem with this routine
Old Mar 18, 2010 | 07:34 AM
alnielsen's Avatar
I don't do anything special when I shut down the car. I even shut down after moving from the driveway to the street parking. I've never had a problem with flooding. On of my RX7's may have flooded once, but I'm not sure of that. It's been a long time ago.
Old Mar 18, 2010 | 08:59 AM
One Shot One Kill
a test i do is if i rev up, let go, and hear alot of POP POP POP POP , it's still too cold and i wouldn't risk shutting it off. (only do this if i know it's still too cold)
Old Mar 18, 2010 | 09:03 AM
ken-x8's Avatar
The actual procedure is described in the Quick Tips booklet, and I think (not completely sure) on the DVD. Not everyone has those. You'd think that a service advisor at a dealer might have learned it, but I guess not.
Revving to 3K isn't a substitute for warming the engine before shutting it off. It's what you should do if you warmed it by idling instead of driving.
Ken
Old Mar 18, 2010 | 09:45 AM
revving the engine when you want to shut it off cold is to prevent gas flooding the engine, not 100% sure but it makes sense
I saw the dealer rev it and turn it off let it spin down with no throttle so no gas gets injected and everything gets pushed out of the engine.
Old Mar 18, 2010 | 08:52 PM
ARE-EX-8's Avatar
Rotary > Piston
Just to clear something up here. SO this procedure ISNT a susbtitute for driving around and warming it up or leting it up warm up by idling right? LIke by doing this procedure you arent in fact warming up the car right ? So confused lol
Old Mar 18, 2010 | 11:01 PM
no it doesnt warm up the engine, it pushes out the gas in the engine
Old Mar 18, 2010 | 11:18 PM
ken-x8's Avatar
This procedure and warm at idle are a substitute for driving around and warming it up. If I might be so bold as to quote Mazda's book (yeah, what do theyknow?):
Short trip driving procedure
For any trip that is too short for the
engine to reach normal operating
temperature, (needle in middle of
temperature gauge indicates normal
temperature), the following
procedure should be followed**:
1. Start engine
2. Move vehicle
3. Warm engine for 5-minutes at idle
4. Raise engine speed to 3000
RPM for 10-seconds
5. Return to idle
6. Turn off engine
Ken
Old Mar 18, 2010 | 11:19 PM
Gray's Avatar
The dealer in Norman, OK told me this exact same thing yesterday. Her reasoning was to "push the carbon out of the engine" but then again she told me I needed to "drive this car like I stole it" so I didn't know what to think.
I'm a new owner as of week ago and I'm loving it so far
Old Mar 19, 2010 | 12:34 AM
xexok's Avatar
You basically do need to drive it like you stole it. Makes for a happier rotary engine. When I called mazda one time they told me the rx8 'has the heart of a race car, and needs to be driven as such' which blew me away, a company telling me to drive like that lol. I'm only to happy to follow their directions though.
Old Mar 19, 2010 | 03:12 AM
WTBRotary!'s Avatar
Drummond Built
Originally Posted by JessiahC
Well, I think you're misunderstanding. Shutting down the engine while rev'd up to 3-4k . It doesn't really have anything to do with the temperature of any fluids. I see where you're coming from though.
Its not the temp of the floods, its engine temp... The engine runs rich on start up until it warms up...
Old Mar 19, 2010 | 04:15 AM
10k is much better ....
One Shot One Kill
you know, i never knew dealer actually start to recommend such driving behaviors, nice =)
