Battery help!!!!
Old Mar 17, 2010 | 02:36 PM
DaRotary's Avatar
Battery help!!!!
So i bought a new battery from mazda 89$ and took mine out. i have some problems i didn't put the steel thing that holds that battery in place i couldn't get it in at all.. is it ok if i dont put it in?
Inside my dash board one of the lights stays on its the DSC slipping car light.
and last thing i wanted to know if the battery i took out is original its a Panasonic made in japan is it the original battery that comes with the car?
Old Mar 17, 2010 | 02:44 PM
you're going to want to secure the battery so it doesn't go bouncing aroud in there.
the DSC needs to be reset. Check your owner's manual.
it requires turning the wheel completely in one direction and then completely in the other.
I don't remember what the OEM battery is, it's been 4 years since I took mine out.
Old Mar 17, 2010 | 07:07 PM
Nubo's Avatar
Lubricious
My original battery (2004) was a Panasonic. I thought they went to some other more powerful battery later that year, or in 2005...?
Definitely get that battery secured. You do not want a heavy battery moving about. At the least it will probably tear up the connections. At worst, it's a flying 40lb lead brick, with acid for bonus points.
Old Mar 17, 2010 | 07:26 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Just changed my late 2005 OEM battery, even though I didn't really have to do so.
It was a Panasonic.
Secure that battery.
As far as the TCS/DCS.................do this.
1.) Turn car on but do not start
2.) Turn wheel all the way to the right, then all the way to the left.
3.) Turn car off
4.) Start as normal and go for a ride!
5.) Once home, either downlaod a manual for free.....or if you have one....read up a little bit.
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Sep 26, 2015 12:30 PM
