royal purple manual transmission fluid
Rating: Thread Rating: 3 votes, 5.00 average.
Old Mar 16, 2010 | 04:56 PM
cory_mcm's Avatar
I did a search and didnt see anything on transmission fluid saw a lot of problems with peoples transmissions but i didnt see any one recomend a certin brand. I went to a few places and the only manual tranny fluid was the royal purple synchromax, and i was wondering does it matter what fluid you use as long as its designed for a manual transmission?
Old Mar 16, 2010 | 04:59 PM
The Reverend's Avatar
That's a lie
A lot of people are happy with Redline gear oil, MT90 in the tranny
Old Mar 16, 2010 | 05:06 PM
rotarygod's Avatar
Syncromax is the wrong fluid to use and I'm sure the reason for many people not being happy with RP. Personally I use RP MaxGear 75W90 in the transmission and differential. Redline and Amsoil are also good choices.
Old Mar 16, 2010 | 05:15 PM
cory_mcm's Avatar
so i could anything that is atf 75w90? does it matter if its a synthetic oil? to me it doesnt matter the cost because whens the next time i have to change the tranny fluid 50000 miles.
Old Mar 16, 2010 | 09:05 PM
BRODA's Avatar
Not yet famous
Old Mar 16, 2010 | 09:29 PM
(SEED)'s Avatar
(>'o')>
why do people make such a big deal about RP?
its fluid........
Old Mar 16, 2010 | 11:12 PM
SayNoToPistons's Avatar
Wheels, not rims!!
its fluid........
When you have a picky transmission like the Aisin in our RX8; not just any fluid is just "fluid".
I'm using the BHR recommended Eneos 75w90. A bit loud when warmed up, but that is totally normal according to BHR. Smooth as butter.
Old Mar 16, 2010 | 11:24 PM
Flashwing's Avatar
3-wheeler
Glad to hear it. I tried a lot of stuff in my tranny including the RP Maxgear and the Eneos is by far the best IMO.
Old Mar 17, 2010 | 12:50 AM
Junirol's Avatar
Toyota Master Technician
Royal purple 75w-90 synthetic trany/diff fluid works out great. Shifting definitely alot smoother than before.
Old Mar 17, 2010 | 01:44 AM
WTBRotary!'s Avatar
Drummond Built
https://www.rx8club.com/showthread.p...ht=transmisson
People dont like Royal Purple tranny fluid because its a GL-5 fluid which has reactive sulfur which can chemically wear brass synchros... GL-4 Fluid has less a less reactive sulfur content or percentage which isnt supposed to wear the Brass synchros- From what I have read...
I do not have any personal experience with RP tranny fluids for the 6MT RX-8, I have used their fluids for when I had my auto RX-8. I used their ATF and 75W-90 for the diff...
Since I do not have any personal experience with RP tranny fluids in the MT RX-8 I cannot say the fluid will actually do this but I do not want to take a chance, which is why I chose Redline MT-90 for my Transmisson fluid and 75W-90 for the Diff. Rather safe than sorry....
Old Mar 17, 2010 | 05:05 AM
(SEED)'s Avatar
(>'o')>
well i can certainly see (different) gear oil makeing a difference on noise concerns.
But the people who claim their car got noticeably faster when using royal purple oil in their engine...... id say their full of it until i see some dyno charts and data logs.
it all sounds like some ricer **** to me
Old Mar 17, 2010 | 08:16 AM
Marc_GS's Avatar
Hooked on go-fast crack
its fluid........
A lot of us who have used it have had problems. In my case, I got a 4th gear grind very shortly after starting to use it. I switched to a GL-4 fluid (Pennzoil platinum, IIRC), and it got better, but was still there.
And, for the record, I did use the Maxgear 75W90.
Old Mar 17, 2010 | 08:58 AM
Solidtrance's Avatar
Use the GL4, which is designed to be gentle to gold metals like brass synchros.
Many a parts counter guy will do their best to sell you the GL5, saying things like "supercedes the GL4" and/or "replaces GL4 for all uses". Nevertheless, there is a reason Mazda specs GL4 for the tranny and GL5 for the rear diff. In my reasearch this was backed up by my Amsoil rep, who suggested the same GL4 & GL5 package as spec'd above. Wasn't even a question for him, it was as simple as "Lube for a manual tranny, you need GL4."
Old Mar 17, 2010 | 10:08 AM
lepichichi's Avatar
I LuV mY Rotary....
i used royal purple before and my tranny was grinding from 1st to 2nd at high rpms, i then switch to redline and problem solved. Stay away from royal purple use redline.
Old Mar 17, 2010 | 10:41 PM
Wheels, not rims!!
Where did you read that?
Old Mar 18, 2010 | 02:30 AM
its fluid........
let me spell it out for you ...
r-e-t-@-r-d-e-d
Old Mar 18, 2010 | 08:39 AM
rotarygod's Avatar
I know many people using RP in transmissions, yes even in RX-8 transmissions, that have no issues at all. I firmly believe it's how the car is treated by owners that kill transmissions and nothing else.
Old Mar 18, 2010 | 09:57 AM
RG, do you thing the diference between GL-4 and GL-5 is not a big deal? I think the problem that most people have with RP is that their local parts store only stock the GL-5 version which is great for the diff but not good for the trans. I deffinately do agree that our trans needs to be used properly. It does not respond well to voilence or rought shifts.
Old Mar 18, 2010 | 10:21 AM
redcopper06's Avatar
'06 copper red shinka #66
redline mt-90 in the tranny,
http://www.redlineoil.com/product.aspx?pid=46&pcid=7
and redline 75w90 + Limited Slip additive in the rear if you have L.S.
http://www.redlineoil.com/product.aspx?pid=133&pcid=4
http://www.redlineoil.com/product.aspx?pid=41&pcid=4
Old Mar 18, 2010 | 10:22 AM
and it is a big deal. if you put the GL-5 in your tranny kiss it goodbye after about 10k miles
they are very different.
https://www.rx8club.com/series-i-tech-garage-22/gl5-vs-gl4-gear-oil-transmission-159398/
Old Mar 18, 2010 | 01:17 PM
Wheels, not rims!!
The Eneos 75W90 fluid recommended by BHR I'm using is GL5. I highly doubt I'll be kissing my transmission good bye anytime soon.
Old Mar 18, 2010 | 01:52 PM
maybe you wont, and maybe you will...
https://www.rx8club.com/rx-8-discussion-3/possible-clutch-bearing-transmissino-issue-184930/
Old Mar 18, 2010 | 03:00 PM
WTBRotary!'s Avatar
Drummond Built
Not all GL-5 fluids have the same amount of chemically reactive sulfur, I remember reading some have more and some have less than their stated value of GL-4 or GL-5... so far Eneos 75W-90 is the only GL-5 Fluid that works in the RX-8 Transmisson and is fine...
Old Mar 18, 2010 | 05:35 PM
evolvnola's Avatar
did you try the ams oil
Old Mar 18, 2010 | 07:08 PM
Wheels, not rims!!
I'm well aware of that. Unfortunately, some aren't.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
