Starting Problem
Old Mar 15, 2010 | 07:07 PM
simpsonn's Avatar
Starting Problem
It's an '05 RX8 and I just had the spark plugs, coils, battery replaced about two months ago. Recently got a new car and I was out of the state for about a month so the car sat in a non heated garage for that month. When I went to start it up today all the electronics turn on and it sounds like it has full power when its turning over but theres no firing/spark when turning the key. Any ideas?
Old Mar 16, 2010 | 12:47 PM
Old Rotor's Avatar
Check battery voltage. Your battery is being used even when it sits there. Put a battery charger on it now and a trickle charger when you go away for more then a couple of weeks.
Old Mar 16, 2010 | 01:21 PM
Silverisk8's Avatar
true... if you haven't turned it on in a while your battery is drained... if you have a closed garage , next time you decide to not use it , don't activate your alarm, just lock the doors manually with no alarm activation, this will help to reduce the battery from draining.. trust me I do it all the time and it works ....good luck !!!
xAgyex
Jun 3, 2026 03:47 PM
Jaco Greyling
Jan 6, 2019 08:39 AM
uZu
Dec 30, 2015 12:35 PM
Tyblat
9
Aug 6, 2015 10:43 AM
robd1337
Jul 31, 2015 09:35 PM
