RX8 paddle shift problem
Old Mar 15, 2010 | 11:40 AM
Crashas15's Avatar
FL RX8 paddle shift problem
I have a 2005 RX8 atuto transmission with the paddle shift on the steering wheel. I am having trouble with the paddle shift. It will not shift up but does shift down with no problem. Car has 30k miles and has no other problems. It shifts OK with the stick in manual mode. I talked to the service manager and he has never seen the problem so naturally it's a hundred dollar diagnosis fee. If anyone can help I would appreciate it. It sounds like a microswithch adjustment in the steering wheel to me but the serviceman wasn't as positive.
Old Mar 15, 2010 | 01:00 PM
EDZRIDE's Avatar
2005 White GT
Both upshift paddles? If so, it's probably the up switch
Old Mar 15, 2010 | 01:16 PM
Easy_E1's Avatar
Paddle shifters do fail. I lost the up shift one on the right side. Phils8 lost the same one. They do go bad.
Can you shift normal with the regular shifter? And is it one paddle shifter that wont shift up or both?
Old Mar 16, 2010 | 08:46 AM
Crashas15's Avatar
Shifts fine on the stick. Both up paddles are out. Where is the problem and how much trouble to fix? john pontus15@aol.com
Old Mar 16, 2010 | 12:58 PM
EDZRIDE's Avatar
2005 White GT
This will probably be a dealer repair but here is the link to the repair manual: http://www.myrotarycar.com/portal/fo...3le/index.html
Look in the transmission section, sympton troubleshooting, sympton 31/32.
Dokuji
Nov 1, 2016 02:51 PM
xandersonx97
Aug 2, 2015 01:02 AM
Belalnabi
Jul 17, 2015 07:48 PM
reverse01134
Jul 16, 2015 10:27 PM
