Stance GR coilovers fast question
Old Mar 15, 2010 | 11:40 AM
Pico's Avatar
It's Complicated
After doing some research I've decided to buy a set of Stance GR's because of the positive feedback I've read here and other forums.
I wanted to know if your are anything's I should be aware about when installing- pre-load, ride height, etc.
Also, after installing how much do these coilovers settle over time?
Any help form people with these installed would be great. thanks guy
-Neil
Old Mar 16, 2010 | 12:41 AM
TopGear8's Avatar
mkuhnracing.com
They don't take anytime to settle. You don't adjust the height of the springs, you adjust the height of the shock...Watch Rishie's video that he posted in his thread.
The only problem some of us have had is that the upper rear mounts were backwards. You'll see what I mean when it comes time to install it, If they fixed it, then good, If not, then just unscrew the mount from the shock and turn it around, not hard at all.
Old Mar 16, 2010 | 05:33 PM
Pico's Avatar
It's Complicated
I've watched his vids-- very helpful
Do you remember what your measurements were in the rear between the two mounting points? Just wanted to know because as you know the rears are a PITA and it would be nice to mount them up just once without having to do it twice and uninstall the whole assembly.
I'm thinking of going with 9k front and 6k rear--- will this make for a comfortable ride for daily travel?
Thanks for the info bud
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
yankeepicker
Sep 11, 2015 05:42 PM
